Pre 84 Trucks 1st gen pickups
Any fix for a slow / non respnsive tach?
Old Mar 5, 2010 | 11:54 AM
Ilovemountains's Avatar
The tachometer in my Trekker works sporadically , I noticed that when it warms up in the cab it starts to work but isnt very accurate, I know this is a dumb question but can you lube a tach with graphite or Teflon??
Old Mar 5, 2010 | 12:26 PM
Gov't Mule's Avatar
Thats REALLY funny man....the tach in MY Trekker is the EXACT same way...I really haven't gotten around to being really annoyed by it yet...when I do, I'll figure out how to fix it. Maybe someone here can shed some light and save both of us some time.
**edit** I was thinking it has more to do with the temp warming up in the engine compartment that makes it start working...I dunno.
Old Mar 6, 2010 | 02:00 PM
Thats funny!! Im thinking that the factory lube inside the tach is a little gummy and when it warms up it starts moving but Im not 100%, I dont know if I can remove just the tach from the cluster to take it apart and see if the needle has resistance or if its just worn out!!! Must be a Trekker thing!
Old Mar 7, 2010 | 04:41 PM
Gov't Mule's Avatar
It was warm today...my tach was workin fine....lol.
Old Mar 7, 2010 | 06:36 PM
dropzone's Avatar
Fossilized
since you guys are 82 Trekker owners I will make you a deal on an 82-83 instrument cluster if your want it..got it off ebay thinking i was gonna convert my '81 but I don't feel like messing with converting to a square plug etc...reads 110980.x on the odometer...
than you can play with the tach to experiment...think it is a 2wd...basically just need enough out of it to cover shipping...
Old Mar 7, 2010 | 06:57 PM
jrobertson4runnner's Avatar
The tach on my 4Runner is going wacky too. Sometimes its too slow, sometimes its too fast. Any ideas? OP: sorry, just didn't wanna get flamed on for starting a new thread.
Old Mar 7, 2010 | 07:04 PM
Teuf's Avatar
A cable runs a tac? You funnin with us?
Old Mar 16, 2010 | 08:54 AM
turn1andburn1's Avatar
Yup my 84 4runner has the same problem till it warms up.. Weird.
Old Mar 16, 2010 | 11:03 AM
83's Avatar
83
No way! Tach is fully electronic. Mine runs off the coil. There is a spring/wound thingy in there that allows the needle to move, if it's anything like the speedometer needle. You could carefully take it apart and see if it's gummed up, but I'd also wonder if it's not an electrical connection issue. My stereo in my truck only works when it's warm out...and obviously that's all electrical.
When I did the conversion from a standard cluster to an SR5 cluster, I actually took my mileage marker from my old cluster and moved it to the new one, so I messed around with the speedometer needle a bit. There's a (like I said) coiled wire set up that allows it to work the way it works. When I first put mine back together, it was bouncing on 0 when I was driving forward, and moved up when I went in reverse.. obviously I put it in the wrong way, so I had to do it the opposite way then it worked. Anyways, other than something electronic, that's the only part that could possibly require some "lube" or something. My guess would be that it's electical..
Old Mar 16, 2010 | 05:09 PM
Gov't Mule's Avatar
Yeah....I'm pretty sure it's an electrical "resistance" issue due to the fact that it's affected by temperature.
Old Apr 20, 2010 | 07:18 PM
1980 4x4's Avatar
Anybody have anymore ideas here? I was going to take my cluster out and mess with it a bit to see if I can figure anything out. My tach seems to only work when it is cold outside haha!!
Old Apr 20, 2010 | 08:37 PM
yota81's Avatar
i don't havev any advice, but my tach on my 81 works only when it wants to...hot or cold.
crammit442
7
Nov 29, 2017 12:30 PM
rednecktoyotahunter
Nov 18, 2015 08:58 AM
94ofCanada
Aug 14, 2015 06:37 AM
Crgrey42
Aug 10, 2015 04:23 AM
91yotapup
Jul 27, 2015 07:19 AM
