adding powersteering
i got a 82 4x4, base model i think. i want to add power steering and was wonder if anyone has a DIY? if the SR5 has power steering, that would be the set up i would like to add. thanks for the help
Should all bolt right up given the same engine and solid axle up front.
Put the stuff in the box below (plus the tensioner and bolt-on crank pulley):
on the engine and frame. The page below has a bit about how I pulled the stock p/s off mine:
- http://www.4crawler.com/4x4/CheapTri...html#Hydraulic
off the top of my head I believe that there also needs to be a mounting bolt in the head for the PS pump mount.
This download: http://ncttora.com/fsm/1985/1985FSM_OCR.pdf is for the 85 Factory service manual but much of it will apply to 79-85 SA trucks
irv
10-01-2015 09:49 PM
JookUpVandetti
09-30-2015 08:58 AM
sonorn67
09-19-2015 05:39 PM
