Pre 84 Trucks 1st gen pickups
81 pickup battery light
Old May 19, 2011 | 03:01 PM
nemethjames1's Avatar
i am having problems with my battery light comming on. i put a new alt in. and the voltage is always around 14.4. when the light comes on i hit the dash and it goes off. its only the battery light not the brake.. when the lights on or off voltage is good. any thoughts?
Old May 19, 2011 | 04:25 PM
swampfox's Avatar
I have read that a bad solder joint in charge light relay can cause this problem. assuming that you are hitting the dash on the side that the relay is on.
Old May 31, 2011 | 06:08 AM
truckman1966's Avatar
replace your charge lamp relay
Old May 31, 2011 | 08:38 AM
JustDSM's Avatar
Anyone have a picture to indicate exactly where this relay is located?
Old May 31, 2011 | 07:19 PM
I don't have a picture, but it's right side of the steering column, up under there pretty far, and it says charge relay on it.
Old Jun 1, 2011 | 04:09 PM
swampfox's Avatar
It could also be on the passenger side ,above the kick panel under the dash.
Old Jun 1, 2011 | 11:56 PM
dropzone's Avatar
Fossilized
Was curious about this too, my charge light has never come on...good reminder for me to check the bulb/connection someday
Old Jun 2, 2011 | 11:43 AM
JustDSM's Avatar
Mines on and off.. Just something else to fix..
Old Jun 2, 2011 | 11:45 AM
dropzone's Avatar
Fossilized
at least it lights up sometime
Charecter1
Nov 6, 2023 10:08 AM
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
skoti89
Jul 8, 2015 12:05 AM
colinmil
Jul 6, 2015 04:03 PM
