Pre 84 Trucks 1st gen pickups
3 broken rings, 1 piston and spun bearings - Options?
Old Dec 22, 2006 | 01:34 PM
dcg9381's Avatar
Get a core block and rebuild it right for under $500. IF you know how to take it apart, it's not that big a deal to reassemble it... I haven't seen one fail like that.. I wonder if it ran out of oil or something? A failure 2 hours later is suspicious.
A chevy 350 will work, of course, but read all about the cooling issues you'll run into. Nevermind that your driveline wasn't designed for that kind of brute torque - you're talking a few thou if you can do the fab to get it in there.
The number of wires required to run a 22R is minimal.. It doesn't suprise me that the wiring is hacked up.
IF it's already geared, might want to stick to something with similar manners as a 22R.. 2RZ, 3RZ - otherwise add a regear to the list of "todo" for the 350 swap.
bigjstang
Jun 2, 2025 03:56 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
dumpster84
Apr 30, 2016 06:03 AM
Iceman4193
Aug 28, 2015 08:43 PM
JimiJams
Aug 7, 2015 01:36 PM
