Pre 84 Trucks 1st gen pickups
Electrical issues
Old Dec 10, 2006 | 10:08 AM
SLCyota's Avatar
Electrical issues
My 82 pickup that I bought about a week ago will not take/keep a charge. I had the battery checked out; it came back good. I replaced the alternator, checked grounds, and the truck still dies. The battery and brake light are on and haven't turned off even after the battery was fully charged. Is there any things that often go wrong with these trucks that I should check?
Thanks
Old Dec 12, 2006 | 09:40 PM
SLC97SR5's Avatar
SLCyota;
Welcome, are you in SLC, UT?
I believe you have an external voltage regulator. Some were electronic and some were mechanical/vibrating type. Make sure you've got the correct one for your ALT.
The CHARGE light is indicating a draw on the battery, that's why it show's even though the batt is charged.
Have you checked ALL the fuses and fusible links?
Old Dec 12, 2006 | 09:42 PM
basinredneck's Avatar
regulator, my old bronco did the same thing.
Old Dec 13, 2006 | 05:31 PM
SLCyota's Avatar
Ya, I live in sugarhouse. I have been into dsm's all my life, and decided to get a toyota pickup for a daily/wheeler, but I'm plagued with problems.
I am planning on tearing the wiring apart tomorrow and hopefully figuring out what the problem is. The regulator is the black box that plugs into the alt right?
Thanks for the help guys!
Old Dec 22, 2006 | 10:42 PM
SLC97SR5's Avatar
What did you find out??
Yup, the regulator mounts on the driver side fender above the coil/igniter.
coryc85
Sep 9, 2015 06:24 AM
jjrbus
Jul 27, 2015 11:06 PM
v_man
Jul 23, 2015 04:01 PM
Poncho0206
Jul 10, 2015 06:21 PM
AaronM
Jul 8, 2015 07:15 PM
