Vendors Build-Ups (Build-Up Section) Vendors can showcase customer builds here
Toyota Fiberglass: 1983 Trekker Build-Up Thread
Old May 22, 2008 | 04:29 PM
  #101
slacker's Avatar
so trying to figure out the emergency cable and brake lines ..
first working on the emerg. cable . My final outcome .. is to have the stock cable hook up to a short extension .. heres the direction i'm going ...
I first found some 3/16 cable .. and fittings and such
with an idea in mind , I found a bolt to cut for cable retainers .
I drilled out the center of the bolt , and then cut it in to pieces ...
then " V " grooved to top , an slid the cable up threw the center .. and welded
and "loosly" hooked up !
I checked with the GM dealer today also on the price of the return springs $50 bone each , and the secondary spring leavers .. only available with the calipers .. yeah right so I decided to make my own ..
made a template for the bracket , and started cutting and drilling ....
and finally an install pic ..
loose
and clamped
so far so good ..
Old May 23, 2008 | 04:42 PM
  #102
slacker's Avatar
a little worried the wheels wouldn't fit (REM sleep causes this)
so this morning I fit on my "shop tires" 8" wheels and 31's .. and clearances look good . ;D
also .. got some of the rear brake lines hung .. but am having a problem finding the "banjo" style fittings for my calipers .. help is appreciated !!!
Old May 24, 2008 | 02:21 PM
  #103
slacker's Avatar
so I found the right lines !!!!
First I opened everything up .. and had a look .
I realized my previous "hanging " of the rear line was no good , so I started with moving the rear upper hanger .
welded , and re-bent the line .. I also added some posts for the line to bolt to ...
so with the line now loosly fit ..
I wanted to make the brackets fit my supports .. so I removed the crimping from the new lines , and started cutting and forming and fitting
and now a perfect fit .. and re-crimped back onto the lines ...
here in BC .. brake lines also must be supported with a bracket , and "C" clip ..
so I made some brackets ..
welded and "C" clipped
and used the "domestic ends , and a small piece of line with the original ends on it .. double flared the ends , and done .
Old May 25, 2008 | 04:03 PM
  #104
slacker's Avatar
small project today .. that now I can check off the list .. DONE!
Track bar was a little to short because of the lift , so I had to correct ..
Cut the main rod out , and also cut a new main bar .. notice the diameter differance .
all welded .. and you must be carefull to NOT burn the bushing ..
and installed ..
Old May 29, 2008 | 04:12 PM
  #105
slacker's Avatar
ok .. so I know you guys arnt "keen" on the blocks ..
I ran them in my "white knight" for 12 years .. 36" swampers , ARB's front and rear , and 5:29's .. wayyyyy back in the early years .. so for this build , I'm usin em' .
anyway .. blocks work for space for the new rear calipers , and emergancy cables .
so to make the blocks work .. as on my old rig .. I built some "kicker shocks" there not as harch as a traction bar .. and still allow some movement .. but very limited , and "absorbed"
I first I cut out some brackets
welded them to the frame , with the MOCK-UP shocks in place
then I took the original u-bolt holder , and made some more brackets .. welded , and added some bump stops ..
and now I have a correction for the blocks , and " 0 " loss of clearance .
Old May 29, 2008 | 04:46 PM
  #106
yotasavg's Avatar
great work man!!!
Old May 30, 2008 | 03:08 PM
  #107
slacker's Avatar
thank you !
Old May 30, 2008 | 10:33 PM
  #108
rowdy235's Avatar
excellent job, thus buildup is the best
Old May 31, 2008 | 06:00 PM
  #109
slacker's Avatar
thank you ..
Old Jun 4, 2008 | 03:47 PM
  #110
slacker's Avatar
I wanted to finish up the rear bump stops .. so I unbolted the originals and removed
made some new "low profile" .. and installed
Old Jun 4, 2008 | 03:49 PM
  #111
slacker's Avatar
started a bit of work on the rear emergency cable .
started with cleaning up some of the brackets , and making new ones .
the main "swivel" mount was tapped . leveled and welded .
I picked up some 90* 's off the front cable , (on the firewall) 79-89toys from White Valley Collision
got them all cleaned up ..
I went to incert the cable .. for a test fit .. and found they wouldnt work .. the inner wheel was plastic , as well as not the right fit for the cable ... I didnt think the plastic was strong enough either ..
so I lagthed some new wheels ..
and now cable fits perfect ..
made the new mount brackets ..
braced and tacked into place ..
They seem to be good , although I do have about 1-2 mm of deflection .. I either need to brace them better , make some more supports .. or re-do the brackets in a thicker material ..
Old Jun 5, 2008 | 01:42 AM
  #112
Sked's Avatar
Best rear brake setup ever, you da man. You make me hate my drums even more now
Old Jun 7, 2008 | 04:48 PM
  #113
slacker's Avatar
thanks ....
Old Jun 7, 2008 | 04:52 PM
  #114
slacker's Avatar
so i'm basically FINISHED the emergency cables ..
I decided to weld in a support bracket .. I used the same 1" pipe I have been using for the other supports .. a little continuety .
They are now 100% with zero deflection ..
I also added 1 more support for the cable , didnt want it "rubbing" against the shock body ...
and now I just have to "crimp" the cables .. and done .
Old Jun 22, 2008 | 07:45 PM
  #115
slacker's Avatar
not much to add .. started the POR treatment ...
driveshaft washed .. then de-greased .. washed again . "metal-ready" prepped , and washed as per instructions , and then the POR-15 .
Old Jun 25, 2008 | 04:07 PM
  #116
slacker's Avatar
dude .. I love my stands .. they are totally adjustable , and rotate .. you need a set .
Old Jun 26, 2008 | 05:06 PM
  #117
slacker's Avatar
diff .. and extras ..
springs are in the works .. and soon the frame ..
Old Jun 27, 2008 | 06:53 PM
  #118
slacker's Avatar
springs are done ...
If all goes well ..I'll have the frame done this weekend ..
Old Jun 28, 2008 | 04:14 PM
  #119
slacker's Avatar
springs ..
but there is no way I'm doin' the frame this weekend .. it's 36* C (about 90* F ) outside .. so I'm goin' to the beach ! ..
Old Jun 28, 2008 | 04:29 PM
  #120
rowdy235's Avatar
Nice.........
Project is coming along nicely. Keep up the good work.
