Pre 84 Trucks 1st gen pickups
1983 pickup headlights issue
Old Mar 11, 2007 | 05:48 PM
leonardator's Avatar
i've having issues with my headlights, they don't work. i bypassed the switch and can hear the solenoid clicking, and i put new fuses in, anyone have any idea, the guy i bought it from had hardwired them to the battery on his last trip, then didn't drive it anymore, i know the lights are good, but can't make em work.
Old Mar 11, 2007 | 06:25 PM
4banginRunner's Avatar
are the pigtails new(er)? check those, they are cheap to replace
Old Mar 11, 2007 | 06:45 PM
sure, i'll check em out, i only work on it on weekends so i'll update next week.
Old Mar 15, 2007 | 10:32 AM
ok, so it's not the pigtails, is the relay hard to get to?
Old Mar 15, 2007 | 04:49 PM
My814x4's Avatar
Have you checked the fusible link at the battery there is one for the headlights it may be burnt in two?
Old Mar 16, 2007 | 08:15 AM
4Crawler's Avatar
The one relay and fuses are usually up front:
- http://www.4crawler.com/4x4/4R_TechI...tml#Electrical
Note that the headlights are grounded to turn them on:
- http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
If the headlight switch is otherwise in good shape, bypassing most of the stock wiring might be an option:
- http://www.4crawler.com/4x4/CheapTri...#WiringHarness
Old Mar 16, 2007 | 08:40 AM
INFINITY's Avatar
so do the bulbs work for sure?
how are the grounds?
Old Apr 1, 2007 | 10:01 PM
found it, was the fusible link, thanks for all the tips, and the relay was under the dash near the brake pedal arm, and the fuses are also under the dash.
Old Apr 3, 2007 | 10:34 AM
jheard4794hilo's Avatar
I had the same problem. The headlights are powered straight from the battery terminal. Tighten the nuts that you see on the top of the battery terminal wires.
bigjstang
Jun 2, 2025 03:56 PM
Regency
20
Jan 3, 2020 07:43 PM
mskalmus
May 28, 2017 07:51 AM
coryc85
Sep 9, 2015 06:24 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
