Pre 84 Trucks 1st gen pickups
1982 SBC Swap
Old Jan 27, 2013 | 07:14 PM
  #61
cstone94's Avatar
I think his are the Advance Adapter ones:http://www.advanceadapters.com/produ...ine-mount-kit/
I'm gonna order these tonight.
Old Jan 28, 2013 | 06:46 PM
  #62
cstone94's Avatar
Travis, how is your brothers SM-465 clutch engaged? Is it hydraulic or cable driven?
Old Jan 28, 2013 | 07:42 PM
  #63
travis_h's Avatar
It's hydraulic
Old Jan 28, 2013 | 07:43 PM
  #64
travis_h's Avatar
We are tearing it all out in two weeks to put a different engine with a th350 and 205 in.
Old Jan 28, 2013 | 08:21 PM
  #65
cstone94's Avatar
Originally Posted by travis_h
It's hydraulic
Is that the Toyota Master/Slave? Is that a custom bracket for the slave? The clutch fork doesn't look anything like mine
Old Jan 28, 2013 | 08:37 PM
  #66
travis_h's Avatar
I don't know what the master/slave came from. I didn't look close enough to see a name or anything on it. I can look tomorrow. A lot of the parts on the truck the guy just used what he had I think. We are going to strip it all down an go through it again because its just a nightmare on most of it. The crossmember, exhaust, radiator, wiring all needs redone. Has all same color wires used under the dash spliced in with bare wires and the old glass fuses.
Old Jan 28, 2013 | 09:18 PM
  #67
cstone94's Avatar
Haha, sounds like a good long project! I'll figure something out for the clutch cable.
Old Feb 3, 2013 | 07:30 PM
  #68
cstone94's Avatar
Well, not much has really happened. Got the motor mounts welded in. Next weekend we will mount the flywheel/clutch/pressure plate and hopefully set the motor in.
We found that the radiator is going to have to be mounted in the bed, already have a radiator and 2 fans, 1 push, 1 pull. Just need to fabricate a brace that will hold it at a 45 degree angle for proper cooling. May need an upgraded water pump as well.
Old Feb 3, 2013 | 07:34 PM
  #69
travis_h's Avatar
You can't run a short pump and move the core support any to make a radiator fit?
Old Feb 3, 2013 | 07:47 PM
  #70
cstone94's Avatar
Short pump? If I had a radiator in the front I couldn't have a grill haha.
Old Feb 3, 2013 | 07:56 PM
  #71
travis_h's Avatar
Chevy makes a short and long water pump. If you run a short pump it will give you a little more room. I trimmed the back of my grill so I could move my radiator forward and have a short pump and a thin electric puller fan in mine. Also had to cut my core support out and build a new one and take my hood latch out. I just put pins in instead.
Old Feb 3, 2013 | 08:02 PM
  #72
cstone94's Avatar
I think I'll just mount it in the bed, I have all the materials and a stick welder that I can use. A buddy that I traded all the old 22R motor parts to is gonna get me 2 fans and then i'll run some copper tubing down tucked up and up to the motor.
Would your friend be interested in selling that bracket for the slave cylinder when y'all tear that thing down? Maybe even that clutch fork cause it looks a lot different than mine.
Old Feb 3, 2013 | 08:06 PM
  #73
travis_h's Avatar
He might be, I'll have to ask him about it. I'll let you know once I know. His truck has the radiator in the bed too.
Old Feb 3, 2013 | 08:09 PM
  #74
cstone94's Avatar
Let me know ASAP, that would save me a lot of fabricating and figuring out how to mount something like that. Thank you!
Old Feb 3, 2013 | 08:23 PM
  #75
travis_h's Avatar
Ok will do. I'll try to call him tomorrow to see what he says. You get texts on the number you called from last time? I can text ya what he says so you know ASAP.
Old Feb 3, 2013 | 08:24 PM
  #76
cstone94's Avatar
That would be awesome and yes I do.
Old Feb 11, 2013 | 04:06 PM
  #77
travis_h's Avatar
Old Feb 11, 2013 | 04:07 PM
  #78
travis_h's Avatar
I would probably use the radiator hoses and setup as more of a don't than a do list they didn't do a very good job I thought.
Old Feb 11, 2013 | 05:06 PM
  #79
cstone94's Avatar
Dude, those are perfect pictures! is that his original slave cylinder off the original tranny?
Old Feb 11, 2013 | 05:10 PM
  #80
travis_h's Avatar
As far as I know it is.
