Pre 84 Trucks 1st gen pickups
1980 Ignition Wiring?
Old Mar 1, 2022 | 03:07 PM
djewell87's Avatar
I have a 1980 4x4 with a 20r and GM hei module conversion. I'm not getting power on the wire that goes to the module from the ignition switch. I downloaded the fsm and don't see anything on the diagrams that showes the path from the ignition switch to the igniter. I'm trying to find out if there are any components between the switch and the igniter or color coding or any advice to try to troubleshoot this. Thanks
Old Mar 2, 2022 | 12:03 PM
Lons81's Avatar
Here is a diagram that you can use to troubleshoot the wiring . Hope it helps
Old Mar 2, 2022 | 01:01 PM
djewell87's Avatar
Thanks, that's how everything is wired up. I'm not getting power from the ignition switch here. I’m trying to find out if they're are any other connections between the ignition switch and where it connects there.
Old Mar 2, 2022 | 05:46 PM
Lons81's Avatar
If you PM me here, as I have a good wiring diagram for 81 Toyota truck that I can send you. Then you can continuity checks
Old Mar 3, 2022 | 12:12 AM
djewell87's Avatar
Sent, thanks
Old Mar 11, 2022 | 06:49 PM
Bunny's Avatar
Please post diagrams in the open so the next person who stumbles on the thread in a couple years can fix theirs as well.
Old May 16, 2022 | 12:18 PM
8Trusty's Avatar
Any update? I think I might be having a similar issue
Old May 17, 2022 | 09:13 AM
jeremy harp's Avatar
are those photos from the manual ?
Old May 17, 2022 | 11:18 AM
Lons81's Avatar
Old May 17, 2022 | 12:26 PM
Lons81's Avatar
The pics above were found on Google and match my wiring. I’m still in my restomod process, but that how I wired it
I would do continuity checks from point to point to verify your wiring is correct
davidseaton
Feb 20, 2022 04:18 PM
jessicaleighhughes
Jul 6, 2014 08:38 AM
Jagger_MeisterJE
Mar 4, 2013 08:19 PM
Diesel_Dude874
May 7, 2010 09:08 PM
livetoride88
Dec 7, 2009 01:39 PM
