Pre 84 Trucks 1st gen pickups
1978 20R ignition igniter wiring.
Old Apr 26, 2021 | 07:15 PM
davidseaton's Avatar
My 1978 toyota pickup has a Denso igniter for the ignition. The wires have all been disconnected from the igniter . There are six wires coming out of the igniter. If you are looking down at the igniter, wires coming out from the top are from left to right...
. Black Yellow Light brown
. Light brown
Orange WhiteIf anyone could tell me where these wires go it would be appreciated. Thanks.
Old Jan 24, 2022 | 01:28 PM
westfalia's Avatar
I just took some photos of our 1980 20R. It is very original and I know there is a pic of the ignitor in the album. Take a look. Hope it helps. Google album https://photos.app.goo.gl/zcmzb8hZtZUKnoqq6
Old Feb 20, 2022 | 04:18 PM
13Swords's Avatar
5 Year Member
Don't have a diagram handy for the '80, but here's what I have for a '78. I assume it should be very similar.
Basically, the Igniter is a Power Transistor circuit that turns the Ignition Coil on & off. The Red and White wires go to a pickup coil in the distributor, which produces a small current (about 3 volts or so) via induction (a magnet passing by a wound coil of wire around a magnet, basically a generator).
There is a metal wheel on the distributor shaft that has raised vanes on it. When each of these vanes passes by the magnet, it induces a voltage in the pickup coil. This is a "signal voltage" used by the Ignitor circuit. It signals the Power Transistor inside to switch the Ignition coil on & off.
Mine has 5 wires instead of 6. The Ground should be solid black. No idea what the light brown wire might be for, maybe for a factory Tachometer in the dash? If that's the case the light brown wire should be coming off of the negative terminal of the Ignition Coil & goes to the tach.
cregs1119
Dec 17, 2012 05:01 AM
ojm3
Dec 12, 2012 04:55 AM
77FJ40_79PU
Aug 6, 2010 10:31 AM
redneckabbott
Jan 10, 2008 03:56 PM
