for sale 96 3.4 engine 100k mi. in nc
the engine is from a 96 T100 with 100k mi.. it looks like it was in a head on, drivers side motor mount is bent, and the bracket mount on the intake is partially broken off, but repairable, if needed, i did not need this bracket on my swap. the intake is usable. the harness is cut(salvage yard) the timing belt cover, and the fan mount bracket is gone. i was going to use this engine for my swap, did'nt find a harness so i ended up going with a 2000 4runner engine, trans, harness and ecu from the same car. i swapped the oil pan,sump and dipstick from my 4runner engine, i have a oil pan from a 3.0 ( same as T100)for a swap. this engine is very clean inside and out, no oil leaks etc. i would change the timing belt water pump before install.
you can check out these guys. you know where to ship it to,residence, business or terminal. i can crate, and deliver in their truck from a business with a forklift in Monroe N.C. http://www.uship.com/
yes i do.
let me find the shipper i found that has reasonable rates.
i will need more info to get a quote so i will pm you when i find it.
it will be more expensive to have it shipped to a house rather than a business with a forklift, or you pick it up at a trucking terminal.
