Engines - Transmissions Place above type items here
for sale 96 3.4 engine 100k mi. in nc
Old May 13, 2012 | 12:18 PM
donomite49's Avatar
1996 3.4 engine only. 900.obo
monroe nc
Last edited by dropzone; May 19, 2012 at 04:54 AM. Reason: added required location
Old May 19, 2012 | 04:53 AM
power10er's Avatar
Can you send me some details on the engine? Is it a rebuild, any problems at all, and any other info you can give me?
Old May 19, 2012 | 08:11 AM
donomite49's Avatar
the engine is from a 96 T100 with 100k mi.. it looks like it was in a head on, drivers side motor mount is bent, and the bracket mount on the intake is partially broken off, but repairable, if needed, i did not need this bracket on my swap. the intake is usable. the harness is cut(salvage yard) the timing belt cover, and the fan mount bracket is gone. i was going to use this engine for my swap, did'nt find a harness so i ended up going with a 2000 4runner engine, trans, harness and ecu from the same car. i swapped the oil pan,sump and dipstick from my 4runner engine, i have a oil pan from a 3.0 ( same as T100)for a swap. this engine is very clean inside and out, no oil leaks etc. i would change the timing belt water pump before install.
Old May 21, 2012 | 03:06 AM
power10er's Avatar
Any ideas on crating and shipping costs to 39180
Old May 22, 2012 | 02:22 PM
donomite49's Avatar
will check and let you know.
Old May 24, 2012 | 10:19 AM
donomite49's Avatar
you can check out these guys. you know where to ship it to,residence, business or terminal. i can crate, and deliver in their truck from a business with a forklift in Monroe N.C. http://www.uship.com/
Old Aug 23, 2012 | 04:45 PM
donomite49's Avatar
new lower price
Old Sep 21, 2012 | 06:39 AM
AJatx's Avatar
is the bracket on the intake manifold the throttle cable bracket? i need a throttle cable bracket if you can part one out, even if it's partially broken.
Old Oct 23, 2012 | 03:27 PM
donomite49's Avatar
i'll have to check, it's been a while since i've looked at it.
Old Nov 26, 2012 | 09:15 AM
donomite49's Avatar
still have.
Old Dec 11, 2012 | 03:23 PM
Ol Yota's Avatar
Hey is this still available,if so what's the new price??? I'm in Greensboro so I'm not that far from ya...thanks
Old Dec 15, 2012 | 06:22 AM
donomite49's Avatar
still have ,PM sent.
Old Jan 14, 2013 | 05:16 PM
Red Wagon's Avatar
Do you still have this engine?
Old Jan 17, 2013 | 06:25 AM
donomite49's Avatar
yes still have the engine.
Old Mar 11, 2013 | 09:17 AM
donomite49's Avatar
bump.
Old Mar 13, 2013 | 03:35 PM
donomite49's Avatar
still for sale.
Old Jun 10, 2013 | 05:05 PM
donomite49's Avatar
uhhh bump.
Old Jul 7, 2013 | 03:13 PM
Tyler1820's Avatar
Do you still have this engine can you ship it? I live in oregon
Old Jul 12, 2013 | 04:54 PM
donomite49's Avatar
yes i do.
let me find the shipper i found that has reasonable rates.
i will need more info to get a quote so i will pm you when i find it.
it will be more expensive to have it shipped to a house rather than a business with a forklift, or you pick it up at a trucking terminal.
Old Jul 12, 2013 | 05:13 PM
Swimmerboy2112's Avatar
Good deal on this motor, found one on craigslist near me with 200K on it for $2,000.
Good luck with sale!
