Early ('81-84) 22R heads for sale - Performance and stock!
I have 2 early style ('81-84) heads for sale ***Note*** these will NOT work with the later model motors as the block heights and combustion chambers are different
Head #1
Hard to find early model head - Stock clean head great for rebuild or to replace a warped or cracked head on your '81-84 motor. $100 + shipping - No Springs, valves, or rocker arm assembly included although they're pictured in the images below
Head #2
Hard to find early model head already cleaned, decked, and bored for the oversized valves - ready to go. LCE Engineering Pro Bronze manganese valve guides and upgraded Stage 5 SS valve seats installed along with brand new Viton style Pro valve seals. Comes with standard HD springs (not double) and Italian SS valves (Springs not shown in the images below) $250 + shipping
see images below
Reason: added images
The engine that blew up in my '89 4runner had been swapped out previously for an 81-84 early model block. After hot tanking and checking the block, they were going to have to sleeve it and do a bunch of work on the areas that the thrust washers went as the crank had been bouncing around and had more or less trashed the block. I pulled a later model block out of the junk yard and had the machine shop bore it .40 over and do the work on the head. However, they installed and did all of the work on the original head not realizing that it didn't mate up with the later model block. I ended up having to get a new LCE head for my current engine (there was a crack in the one from the junkyard), but had the freshly machined early model head with all the goodies installed left over an no lower end to put it on.
my late model engine installed.....
All work was done by Ledford Performance Machine in Waco Tx.
