22R Engine Parts - SE Wisconsin
22R Engine Parts - SE Wisconsin $2. - $50.
Parted an engine with a rod knock so the good parts are up for sale.
Valve Cover - $15.
Cylinder Head - $50.
Timing chain, tensioner, plastic guides - $10 for all.
Distributor - $30. - Sold
Plug wire set - $5. - Sold
Intake Manifold - $20.
Flywheel - $25.
Carb (Runs) - $30.
EGR Valve - $20.
Knock sensor - $2.
Crank Pulley - $10
Engine Mounts - $10.
Timing Chain Sprocket - $10.
PM me with any questions. I can ship anywhere. Located in Beloit WI.
Valve Cover - $15.
Flywheel - $25.
Carb (Runs) - $30.
EGR Valve - $20.
Knock sensor - $2.
Crank Pulley - $10
i could use motor mounts, main bolts, crank bolt, cam bolt, the drivers side water pipe return that bolts to the side of the block, and if you have the "no.2" crank pulley needed to run power steering i need that and the 4 little bolts that hold it on too. im sure there is more i need, but that my list so far.
