Engines - Transmissions Place above type items here
22R Engine Parts - SE Wisconsin
Old Jul 9, 2012 | 07:55 AM
gyoas759's Avatar
22R Engine Parts - SE Wisconsin $2. - $50.
Parted an engine with a rod knock so the good parts are up for sale.
Valve Cover - $15.
Cylinder Head - $50.
Timing chain, tensioner, plastic guides - $10 for all.
Distributor - $30. - Sold
Plug wire set - $5. - Sold
Intake Manifold - $20.
Flywheel - $25.
Carb (Runs) - $30.
EGR Valve - $20.
Knock sensor - $2.
Crank Pulley - $10
Engine Mounts - $10.
Timing Chain Sprocket - $10.
PM me with any questions. I can ship anywhere. Located in Beloit WI.
Old Jul 31, 2012 | 06:43 PM
krack's Avatar
Will carb timing cover fit an efi motor
Old Aug 4, 2012 | 01:31 PM
krack's Avatar
Have you sent that timing cover out yet bro
Old Aug 5, 2012 | 08:38 AM
gyoas759's Avatar
Boxed up and will be on it's way tomorrow by Priority Mail so you should have it Wednesday or Thursday at the latest. Thanks!
Old Aug 11, 2012 | 07:27 AM
84'yota's Avatar
still have the carb?
Old Aug 12, 2012 | 06:12 PM
kawazx636's Avatar
What shape is that cylinder head in?
I'm interested in using it for a rebuild, could you send me a pic?
Old Aug 13, 2012 | 02:04 PM
krack's Avatar
Thanks for the cover bro still not a full member so it won't let me give u feedback soon as I am I'll leave good feedback great seller guys and a pleasure to do business with
Old Aug 24, 2012 | 04:31 PM
phylo's Avatar
Do you still have the carb available? and if so what is the number on the carb? What year vehicle? Is it an aisan?
Old Sep 2, 2012 | 06:20 AM
arlindsay1992's Avatar
I'm also interested in the head as long as it's not cracked and all the threads are good.
Old Sep 19, 2012 | 09:36 AM
4x4jeffyota's Avatar
interested in head too. I need one now!!!
Old Jan 11, 2013 | 01:23 PM
punchy11's Avatar
PM sent on crank pulley
Old Feb 13, 2013 | 03:28 PM
Nathannich29's Avatar
I'm looking for a engine wire harness for a 1987 Toyota pickup 4wheel drive Manuel shift it has either a 22r or a 22re in it not sure
Old Feb 13, 2013 | 04:54 PM
krack's Avatar
[Got a 22re harness (efi) 22r is carburated pm me if ya need an efi harness k
Old Feb 13, 2013 | 04:56 PM
I need either one
Old Feb 13, 2013 | 05:00 PM
krack's Avatar
U no if an 85 will work everything is the same if I'm right got a lot if efi stuff went propane
Old Feb 13, 2013 | 05:12 PM
It should that's what my brother n law said
Old May 5, 2013 | 08:59 AM
Killgore Trout's Avatar
i could use motor mounts, main bolts, crank bolt, cam bolt, the drivers side water pipe return that bolts to the side of the block, and if you have the "no.2" crank pulley needed to run power steering i need that and the 4 little bolts that hold it on too. im sure there is more i need, but that my list so far.
Old May 18, 2013 | 12:44 PM
gundok's Avatar
Hi you have an oil pump avail? Thx
Old Jul 17, 2013 | 07:06 PM
DMG's Avatar
DMG
How much for the carb shipped to 15216?
Old Sep 8, 2013 | 03:36 PM
TopDawg_43's Avatar
Do you still have the intake? I'm in need of a carb intake.
