Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
what works better than PB Blaster?
Old Nov 18, 2008 | 06:00 AM
desertcox05's Avatar
another + for kroil. also marvil mystery oil is very good, it comes in a gallon can and you can buy it at a.z and advance. read the can too good for lots of other things.
Old Nov 18, 2008 | 06:26 AM
rdlsz24's Avatar
My dad and I have had good luck with this stuff:
It freezes the rust so it gets brittle and breaks loose.
Rob
Old Nov 18, 2008 | 07:08 AM
GSGALLANT's Avatar
At the nuke plant where I work, the shops use methyl salicylate (oil of wintergreen). I've used it a few times, and a little does go a long way (you typically apply it to the nut/bolt with a small syringe). It is expensive, though. Does it work better than PB Blaster? Not sure... I've had good luck with PB Blaster as well, but wintergreen seems to work a bit faster.
ashersullivan88yota
Jan 18, 2022 05:37 PM
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
madxman21
Jul 9, 2015 10:26 AM
