Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
What size sockets for tanny differential?
Old Nov 22, 2005 | 02:08 PM
..........Sorry for the lame question but I'm away from home and need to buy the propper size sockets to remove the drain plugs for the Diffs, tranny, and transfer case on an 88 Runner. Anyone know off hand??? Thanks for your time................TIM
Old Nov 22, 2005 | 02:22 PM
Bob_98SR5's Avatar
tim,
i dont know specifically for your vehicle, but when you are buying tools, always buy the set. at least for my 98 4runner w/ V6, you will need different sizes for all of the plugs you mentioned---the rear diff being the largest.
just buy yourself a large set of metric tools and then you'll be covered just fine
bob
Old Nov 22, 2005 | 02:34 PM
JamesD's Avatar
When working on Toyota's, these are the sizes you need:
8,10,12,14,17,19,21,22,24,30,32,36mm. To answer your questions you need 24mm and 17mm for the trans and diffs. I believe the fill plug for the tranny is 17mm and the diff and the transfer case is 24mm.
James
Old Nov 22, 2005 | 03:11 PM
vegaskurt's Avatar
Pretty sure the front diff needs a 10mm (drain) and 12mm hex head (fill).
Old Nov 22, 2005 | 03:22 PM
Thanks guys........ have tools at home just need enough to get me through this. Don't leave home without tools. Thanks again.........TIM
justdifferentials
14
Jun 11, 2017 08:36 PM
gp66
Sep 14, 2015 12:10 AM
Gravel Maker
RuffStuff
Sep 8, 2015 05:46 AM
gp66
Sep 7, 2015 08:29 AM
BigMike
Marlin Crawler
Sep 3, 2015 07:49 PM
