Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
Welding application specs
Old Feb 24, 2006 | 06:18 PM
shawnhog's Avatar
Hey all,
I am looking into getting a light-duty welder for my general fabrication needs. I am here because I want to pick your brains on what will work well for my application. I am aware that most of the lightest welders usually have 20-30% duty cyles, but that is at their maximum rated amperage, which is likely what I will not need. Since my work will be focused on tubular steel, MIG would be a nice way to go for simplicity and minimal cleanup. All in all, if I am using 1.5" DOM tubing combined with steel rods and plates up to 1/4" or 5/16", what sort of amperage will I be using to effectively create the deep welds necessary to form a strong piece of work? Would something cheap like a Home-Depot model Lincoln 3200HD fit for this type of thing? It is likely that I will not be welding continuously at 30-minute stretches, anything above 30% duty cylce would likely be overkill, since these ARE weekend projects.. Should I look for a 110A to 120A welder? What do you think?
Old Feb 24, 2006 | 06:47 PM
waskillywabbit's Avatar
I got that welder and using the flux core wire it'll do up to 5/16" thick material no problem, but it is a bit messy w/ spatter. The MIG wire won't do anything thicker than like 1/8" thick I think...don't remember, but I've welded quite a bit and I've yet to overheat it. It works well for my weekend/weeknight madness.
Old Feb 25, 2006 | 08:05 AM
shawnhog's Avatar
You used this welder on your project "wabbit?" If you did, now I know that this welder is PERFECT for what I want to do! In all seriousness, though, what did you use for your projects? I really like your webpage, too! Very nice, detailed pics of your pride and joys!
Old Feb 25, 2006 | 09:37 AM
I've used it on my project, but most of my welding on the suspension components was done w/ a Miller 210 that a buddy of mine has...it was before I had my own welder...but this one would have done it fine.
Thanks.
Old Mar 23, 2006 | 11:37 AM
dfoxengr's Avatar
30% duty means you can only weld 3 minutes out of 10 straight, not 30 out of 100
Old Mar 23, 2006 | 12:48 PM
vegaskurt's Avatar
The people at miller stated that in ideal conditions you can MIG 3/16 with the hobart handler 140. I'm gonna give this a shot tonight. You can easily do 1/4 with flux on it.
Old Mar 24, 2006 | 08:14 PM
dfoxengr's Avatar
try a root, then filler pass.
bevel it some first though.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
Dale Johnston
11
Oct 31, 2015 10:22 PM
Obmi
Oct 4, 2015 11:30 AM
