Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
Opinions on Torch Welding
Old Feb 13, 2010 | 01:44 PM
xxxtreme22r's Avatar
TSC has this small portable $56 torch welding/cutting kit, I am thinking about picking up. Says it welds up to 3/16" steel. Not sure in its cutting ability though. It uses 2 1 lb(???) Oxy Acetylene bottles.
As I have never welded before I think this might be a good start for stuff like sheet metal body work and stuff like a skid plate etc. Would not plan on welding the frame or anything and possibly maybe doing a bumper with it as I think that DOM etc really aint that think anyway right? Also thinking of using it to make a steel square tubing frame for my flatbed.
I know at least from the guys at work the easiest way to learn to weld is to get a MIG and use flux core. But right now even a $300 MIG from Harbor Freight is outta the budget.
Old Feb 13, 2010 | 02:33 PM
xfactor203's Avatar
Gas welding is really sloooooow. That's one big drawback.
Old Feb 13, 2010 | 03:59 PM
4banginRunner's Avatar
Oxyfuel welding is a dieing art. Not all that hard, but I wouldnt recomend it for body work or andthing you want to look pretty.
Practice ALOT before commiting to oxy-welding something worthwhile. Tee & lap joints suck in all positions with oxy-fuel.
Old Feb 14, 2010 | 02:51 AM
91 4Runner's Avatar
I have one, don't do it!. Although it works OK for some things it doesn't/will not weld 3/16 worth a crap... If you are trying to braze almost anything it works great.... I should add that the bottles empty fast that is why it's not good, if you are welding quite a bit, then you run out fast...
Old Feb 14, 2010 | 01:37 PM
TinMan's Avatar
Those little ones are mainly for sweating joints. You will run out of gas very fast. Oxy welding is a lot of fun and good start prior to trying TIG. I would not try it on body panels. it will be way to much heat for way to long. I
Old Feb 14, 2010 | 02:13 PM
x2!
Great for getting the feel of the motion for TIG
Old Feb 14, 2010 | 02:34 PM
thanks for the input guys, maybe I will just wait, but for $56 bucks. lol
Old Feb 14, 2010 | 05:16 PM
4Crawler's Avatar
I picked up one similar to that and it did work for small stuff, but that was about it. You'll burn up a tank of gas just about as you get the steel hot enough to start welding. Would be fine for jewelry or small model making use.
ladybugRC
458
Aug 21, 2020 10:41 AM
Iceman4193
Oct 16, 2015 10:50 AM
Obmi
Oct 4, 2015 11:30 AM
tazman1972
11
Sep 28, 2015 10:32 PM
runnermedic
13
Sep 21, 2015 05:20 PM
