Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
Cutting metal
Old Dec 12, 2006 | 09:44 AM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
Cutting metal
What do yall mainly use to cut metal? I'm talking normal metal like 1/8" to 5/16" or so and also tubing. I'm just curious as to what everyone uses and to see the variety out there. I wish I could afford a plasma or even oxy-acetylene with a bench grinder but i cant have it all...
Old Dec 12, 2006 | 09:48 AM
amgraham's Avatar
I got one of those Dewalt handheld 3" angle grinder/cutters and it has been very useful. I use that and an oxy/act torch as well.. REALLY want plasma though and I will probably get a metal blade for my miter saw soon.
Old Dec 12, 2006 | 09:50 AM
does the angle grinder work well to do actual cuts instead of grinding? do you have to put a different "blade" on?
Old Dec 12, 2006 | 09:53 AM
harpen123's Avatar
I was previously partial to the sawzall spraying wd40 on the blade when it gets hot to make it last a little longer. As of late I use my angle grinder much more its good for a variety of tasks. Just always have extra blades/discs u never know when ur truck is in pieces and u run out of blades.
Old Dec 12, 2006 | 09:59 AM
Ringmaster's Avatar
A die grinder with a cutoff wheel works well too.
If i'm at work, I'll use the plasma cutter to carve peices out. A cuttting torch as a last resort, lot's of grinding involved.
Old Dec 12, 2006 | 10:05 AM
amgraham's Avatar
Yeah, you have to swap the disc. It makes nice, clean, quick cuts with the right disc though.
Old Dec 12, 2006 | 10:24 AM
and practically speaking, what do you use to hold the metal? bench mounted vise? what about for cutting small stuff say a 5"x5" square or something?
Old Dec 12, 2006 | 10:26 AM
jjrgr21's Avatar
for cheap get a 4 1/2" angle grinder and cutting wheel, or a chop saw both are better
Old Dec 12, 2006 | 10:32 AM
vegaskurt's Avatar
I use a 4" and a 4.5" angle grinder for 90% of the stuff I cut. I also have a rigid chop saw and a simple jig saw with metal cutting blades. But if you want a plasma there are some cheap ones on ebay that have gotten really good reviews. PM me if you need a link.
Old Dec 12, 2006 | 11:11 PM
hamstrungtaco's Avatar
i use the wet bandsaw to get the clean cut, mainly depends on the situation
Old Dec 12, 2006 | 11:28 PM
Ringmaster's Avatar
If I'm fabbing something up out of the vehicle, a bandsaw works very well, nice clean straight cut's. Tubing, flatbar, roundbar, angle any of it.
I've got a cheapo harbor freight saw at home but it only accepts up to 4' material. If I need to, I'll haul whatever I'm fabbing to work and use the bigger bandsaw there. It will handle up to 12" material, round or square, rectangle whatever.
For thinner stuff, 1/8", 3/16" I'll sometimes use the diegrinder with a cutoof wheel, for curved peices, or other oddball angles.
Old Dec 12, 2006 | 11:51 PM
bob200587's Avatar
Muriatic acid.
Old Dec 18, 2006 | 07:34 PM
4Crawler's Avatar
Horizontal/Vertical bandsaw works great for me. Started with a 4"x6" unit then a few years ago went up to a 7"x12" saw with coolant pump and hydraulic downfeed.
Even the litle saw did some really big jobs:
http://www.4crawler.com/4x4/CheapTri....shtml#HySteer
And I do have a plasma cutter, 14" chop saw, cutoff wheels for the 4-1/2" grinder, a SawzAll and a portable bandsaw that I will use for some instances. For example chop saw for cutting spring steel, and the hand held tools for cutting stuff off under the truck.
Old Dec 18, 2006 | 09:00 PM
dwh91102's Avatar
I use a chop saw, sawzall, and the last resort is the wizwheel.
Old Dec 28, 2006 | 07:28 PM
Sonofmayhem's Avatar
mikita chop saw w/ a dewalt blade, Checker sawzall, and a checker grinder, it sucks, i wont sas till i have my own plasma. but i did my sliders no problem and will build other bumpers and sliders w/ what i have i wish i could get a plane and break? to build some plate schtuff.
Old Dec 28, 2006 | 10:59 PM
i got an angle grinder so ill get some cutoff wheels and see how i do. im sure without a bench vise cutting small pieces will suck
Old Dec 29, 2006 | 12:51 AM
Elkaholic's Avatar
Ya cutting small pieces with the grinder and cut-off discs sucks, but its doable. Just be very carefull. Once you get the disc in a cut dont turn the grinder at all or it will bind up, tear your work and disc to he11. Once you get the hang of it they're real good and fast. Good luck.
HotNotch
Oct 8, 2015 06:51 AM
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
Pocoyota
Sep 8, 2015 02:41 PM
Fundy Rider
Jul 16, 2015 01:35 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
