Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
Air compressor
Old Nov 5, 2011 | 03:11 PM
OntTaco's Avatar
Air compressor
I am looking at picking up a compressor in the $750-$1200 range and this compressor just came up onsale for $799 at the local farm supply store (TSC), it's a 60gal 16.5cfm @90 PSI 7hp with cast iron cylinders single stage. I would like to be able to do some sand blasting with a pressure pot and use it to run any air tool to repair my own vehicle so it wouldn't be used daily/commercially. would this be able to do this or should i be looking for more CFM and a two stage compressor?
http://www.eaglecompressor.com/air_c...p?recordID=278
Old Nov 6, 2011 | 01:26 AM
wyoming9's Avatar
Smile
That is a hard question to answer a truthful answer could only be maybe.
Sure you could get by!! Will you be happy I can`t say.
It seems no matter how many CFM one has you will find a way to manage to run out of air
Sand Blasting uses lots of air depending on the model
Impacts are not to bad but if your getting into grinders , air sanders they consume air.
I got along for years on a single stage compressor I just had to wait and let it catch up and rest it got so very warm.
I went to a 2 stage compressor 24 CFM at 90 PSI which works a whole lot better.
It all comes down to your needs and what you can live with.
Old Nov 6, 2011 | 03:51 AM
OntTaco's Avatar
how quickly would something like this compressor run out of air using a grinder? would you get a few minutes of work out of it using a grinder or would it be one min of work then pump for a few mins?
Old Nov 6, 2011 | 08:13 AM
4Crawler's Avatar
Figure out below:
- http://www.4crawler.com/4x4/CheapTri...uchAirforTools
mussy01
Dec 13, 2016 08:20 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
RatOmeter
Oct 22, 2015 03:17 PM
calderp
Jul 27, 2015 09:58 AM
skoti89
Jul 8, 2015 12:05 AM
