Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
7 foot bed to 6 foot bed.
Old Dec 3, 2012 | 03:53 PM
JeremyW94's Avatar
Okay, first off Idk if this is the right spot or not but I'm on off my phone and its a bit confusing.
Now, I have around a 7 foot bed and I'm going to get a bed tomorrow that is around 6 foot, I'm wondering what kind of troubles I'm going to run into if any when I convert it.
Truck:
1990 Toyota pickup single cab, 4x4.
Thanks in advance and sorry if this is in the wrong spot.
Old Dec 4, 2012 | 08:08 PM
nothingbetter's Avatar
let me get this straight, you have a long box truck, your picking up a short box, and going to shorten the frame to fix the short box?
Old Dec 4, 2012 | 08:42 PM
ThatGuy1295's Avatar
Your 16 years old aren't you?
Old Dec 4, 2012 | 09:19 PM
dropzone's Avatar
Fossilized
It is all a direct correlation to your still set...
Old Dec 5, 2012 | 05:24 AM
you could make it easy on your self and mount the short box as is leaving a 1 foot gap between the box and cab. Then build a tool box to fill that space.
Old Dec 8, 2012 | 04:52 PM
Ya and you'd probably get 30mpg after doing that also.
Old Dec 30, 2012 | 03:16 PM
PayneInTheYota's Avatar
What does that even mean? The guy is asking for advice, and all you can do is make smart ass remarks? Helpful.
To the poster. If you put a short bed on a long bed body you'll have to cut off some of the frame for it to fit right. Which means your rear bumper mounts will not be in the right spot if they are there at all. Not a big deal just a heads up. Spare tire spot may have complications, too.
Old Dec 30, 2012 | 03:46 PM
MudHippy's Avatar
You have no idea what you're talking about. Helpful.
As a matter of fact...it's a HUGE deal. Because the only way to make it work is to chop a ~1' section out of both frame rails(IN FRONT of the bed, NOT BEHIND it), then weld them back together again. All kinds of fun. And that still does nothing to fix the rear driveshaft length issue, and/or the gas tank size problem, you'll create in the process. Both being too big/long to use with a shortened wheelbase. Not to mention the brake lines, e-brake cable, etc., etc., etc....
Your like the tree huger in a room full of loggers. Go somewhere else if your going to have a pap smear over it.
Most important problem about the swap will be relocating the axle (which is ridiculous), not cutting some frame off.
Old Dec 30, 2012 | 08:30 PM
I didn't give my info any level of importance relative to any other info.
Old Dec 31, 2012 | 07:16 AM
Actually you didnt give any info of any importance.
Old Dec 31, 2012 | 07:36 AM
Dreidel's Avatar
if you cut the frame like mud hippy said you wont have to relocate the axle at all as long as you dont cut behind the front hanger
you could coil up the hard brake lines, to make them shorter, ive had great success with shortening my own drive shaft even though everybody told me i couldn't (hasnt been balanced and its been to 100mph without vibs), i didnt know the gas tank was different i thought they all held 12 gallons like mine but apparently not.
why you hating on 16 year olds i was 16 when i did my own sas without a kit and rebuilt my own motor that ive put 12000 miles on since (problem free i might add)
Old Dec 31, 2012 | 07:46 AM
Dreidel's Avatar
or if your comfortable with welding sheet metal you do a bed bob which you would only be modifying the bed and the very ends of the frame (not as important to cut straight as when cutting the fame in half, this wont sidetrack if you screw it up by accident) and not the whole truck probably easier but i have never done it they is a couple threads on here detailing it though. but the bed bob would probably be the best option here
I8URSVT
Mar 2, 2021 06:23 AM
ToyotaMD
Nov 9, 2015 11:53 AM
Ditch Doc
Oct 27, 2015 03:20 PM
Brodetski
Sep 30, 2015 11:50 PM
87SR5justin
Sep 29, 2015 02:50 PM
