Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
54mm socket question
Old May 23, 2007 | 04:28 PM
weakyota91's Avatar
I guess you could say im preparing myself for cv axle replacement. I need a 54mm socket to remove the nut. I realize thats a very big nut my question do i need the leverage of a 3/4 inch drive ratchet or is 1/2 inch drive 54mm socket good enough. I havent had money to purchase air tools so I am using good ole hand tools still. Thanks guys
P.S. whats the tourque specs supposed to be on that spindle nut?
Old May 23, 2007 | 04:31 PM
ChickenLover's Avatar
A 1/2" drive will be just fine.
Old May 23, 2007 | 04:34 PM
Mister Willie's Avatar
If you're talking about the two large hub nuts with the lock washer betwixt them, you could use a 1/4 inch drive if you want. Those nuts aren't torqued very much. If you torque them too much you'll get a premature failure of the wheel bearings. If you can't find a 54mm socket, I think a 2 and 1/4 inch socket will work too. I've got one if you'll pay shipping you could borrow it and send it back.
Old May 23, 2007 | 04:43 PM
weakyota91's Avatar
yea thats the one. Your right they do hold the wheel bearings in I shouldnt tighten them that much. Not sure what i was thinking lol. I actually will invest in one because with my wheeling i have been doing latley i will break one sooner or later and once i find out how easy it is to replace i will probly be a little more heavy on the throttle and break more than once. Thanks tho.
Old May 23, 2007 | 05:01 PM
4Crawler's Avatar
The socket is large but the torque is not very high:
- http://www.4crawler.com/4x4/CheapTri....shtml#Rebuild
Old May 23, 2007 | 05:19 PM
foot0069's Avatar
Here ya go the Wabbit has got ya covered check this out
Jim
http://www.wabfab.org/products/frontaxle/frontaxle.htm
Old May 23, 2007 | 05:47 PM
It's 2 1/8".
Old May 23, 2007 | 07:41 PM
weakyota91's Avatar
Thanks guys i definetly will get the one off Wab Fab i like the idea that is a 3/8 drive.
RobotMoose
Sep 2, 2015 05:53 AM
trailgoat
Aug 13, 2015 05:54 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TDonkey
Jul 26, 2015 10:14 AM
