Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
3/8 steel cutting advise
Old Dec 26, 2011 | 06:51 PM
775Toy's Avatar
So I'm using some 3/8 steel to make my own shackles . I've used my snap on angle grinder with 3" cutoff wheel to cut 3/8 before and it worked ok , but for smaller projects. I'm looking to cut out 8 shackles 2in wide 7in long. I got a big peice of 3/8 for nothing so I'm gonna use it rather than buying smaller peices to work with. I don't have a plasma , or a band saw. So I'm looking into a better and faster way to rip through this. Any help would be appreciated. Thanks
Old Dec 26, 2011 | 08:16 PM
ambitious1's Avatar
If you don't have a plasma or band saw your pretty much stuck with the zip wheels. I would rather use a 4.5" than 3"....
If that's all ya got though looks like your work is cut out for ya..... (pun intended)
Old Dec 26, 2011 | 09:26 PM
775Toy's Avatar
I think that's all my air snap on die grinder can handle. I may look into getting a bigger cut off disk for a electric grinder I got.
Old Dec 26, 2011 | 09:39 PM
ambitious1's Avatar
Electric would be my choice over pneumatic....
Old Dec 26, 2011 | 09:40 PM
Leviticus6432's Avatar
Do you have a cutting torch... You can cut it out with a torch if your good enough and then clean up the edges with a grinder...
Old Dec 26, 2011 | 09:53 PM
sixstringslut's Avatar
The good old sweat and busted-knuckles hack saw works great for such a task.
Slow steady full length strokes only using down pressure on forward stroke, lifting slightly on return.
After figuring grinding time...you can do this faster than a torch or bargain basement plasma.
If you had access to a real plasma, it may be different. There is nothing on TV anyhow lol.
Old Dec 26, 2011 | 10:01 PM
MP's4R's Avatar
you might be better off having a shop dice them up into the rough shape you want, then you can do the drilling and grinding/shaping with your tools. should save you time and maybe money (cut off wheels are pretty cheap, but they add up fast)
Old Dec 27, 2011 | 02:15 AM
wyoming9's Avatar
Wink
They make zip discs for at least 7" I know I have some.
Would have been easier to just get a piece of 3/8"x2" x?? then all you would need to just zip the 2" length drill your holes and done.
Sometimes free is not always the cheapest in the long run.
Oxy-fuel cutting if your doing it correct you might need to just clean up with a flap disc if you need more than that . You need more practice or be shown how to use the torch.
Electric / air I guess it depends on just what one has to work with.
Old Dec 27, 2011 | 09:00 AM
4Crawler's Avatar
If you have a table saw, I used to use a 10" cutoff wheel in my table saw to cut steel. Works well but you need to make sure the inside of clear of saw dust to prevent it catching on fire. Or use a grinder with cutoff wheel and if you cut about 1/8" deep on both sides, you can snap off the rest bending it back and forth a few times.
Old Dec 27, 2011 | 06:19 PM
775Toy's Avatar
Those are all great suggestions. But I don't have acces to a plasma/ band saw , don't wanna pay a shop to cut them down or to go out and buy 3/8x2 , that would defeat the purpose of getting a slab of 3/8 big enough to make all my shackles for nothing . I think my best bet would buy a 4-6" cut off wheel for my electric grinder. I may also try the hack saw but dang that seems rough. If I were to go out and buy the material then yes 3/8 x2" would be easy but I'm working with what I got for nothing. Thanks for all the replies.
Old Dec 28, 2011 | 11:43 PM
wyoming9's Avatar
Red face
So your labor has no value?
It must be nice to have that kind of time on your hands
I could almost be envious !!
In any case good luck
Old Dec 29, 2011 | 08:24 PM
775Toy's Avatar
My labor is free , I have a family and other obligations but again my time is free and this build is on the budget side. If I were to pay a shop 40$ or so to cut them out I could have just bought some shackles.
But I did hook up with a guy who let me use his plasma! It was my first time with a plasma , the first cut or 2 was a lil ugly but in the end all 8 shackles were cut out in about 30 min.
Old Dec 29, 2011 | 08:28 PM
775Toy's Avatar
Old Jan 5, 2012 | 06:40 PM
775Toy's Avatar
Meh, not factory but will work just fine. These were the rear shackles 6in eye to eye x 2in wide 3/8 thick. I'll post pics tomorrow of the 5" eye to eye for the front.
Old Jan 5, 2012 | 06:52 PM
SCToy's Avatar
grinder and 4 1/2 inch cut off wheels are your best bet for sure. I like Walter zip wheels personally. You can make some darn good cuts with them if you just draw it out, follow your lines and let the grinder do the work.
carefully cut along your line and make a groove to follow. Then just using the weight of the grinder do the cutting and you'll be good.
Old Jan 5, 2012 | 06:53 PM
SCToy's Avatar
haha, never mind you ended up with a plasma. Anyways, next time try using a piece of 1/8th (using a factory edge and clamp it down) for a guide instead of a tube, you can get very smooth cuts that way.
Old Jan 5, 2012 | 07:06 PM
I like the vise / visegrip setup there... lol either way, looks good man!
Old Jan 5, 2012 | 08:52 PM
775Toy's Avatar
Ya for sure man the Tube was wack. I used a price of angle iron stood up on the last couple cuts. It worked way better than the tube as a guide. It was my first experience with a plasma , it was pretty rad but not as easy as it looks with thick steel. I would had defiantly gone 4.5" cut off wheel if I hadn't found a plasma to borrow.
Old Jan 5, 2012 | 08:57 PM
775Toy's Avatar
It actually worked pretty good. I used the vise grips to hold all the plates together while I tried to shape them , and the lil vise to hold them still. The end result is ok, by no means factory but I saved quite a bit of money for a couple hours work. I'm finishing the front shackles tomorrow, I'll post pics of end result.
Thanks for the replies.
Longbed 90
Mar 11, 2019 12:38 PM
runnermedic
13
Sep 21, 2015 05:20 PM
punks_is_4x4
Sep 19, 2015 05:52 AM
seab1209
Sep 3, 2015 05:41 PM
