How to hydrolock your 22re (vid & pics)
Old Jun 14, 2009 | 01:41 PM
jusfloorit's Avatar
Went wheelin in the pine barrons with an Xterra club. Everything was great untill the part where I killed her. I'm at the end of the video.
http://www.youtube.com/watch?v=0r16ciQvMQA
Yeah I know, snorkel, snorkel, blah, blah, way to go.
At least the 22re was easy to work on. When I pulled the plugs and cranked out the water, it looked like Free Willy was under my hood. Put the same plugs back in and cranked the hell out of her. Slowly and surely like watching Frankenstein come alive she was running again.
Unfortunately, I think I bent some valves. She starts and idles but has no power. Probably down to about 50hp. But she did make the 40 mile trip home, slowly.
Here's the link to the rest of the vids and pics on the xterra site:
http://www.clubxterra.org/forums/showthread.php?t=11201
Old Jun 14, 2009 | 02:19 PM
BigBluePile's Avatar
Bummer dude!!!
Old Jun 16, 2009 | 08:19 PM
jusfloorit's Avatar
Yuppers. Did compression test. #1 is pushing about 40psi, not 140, 40psi.
Leakdown test showed either cracked head/cylinder, no coolent issues though, or killed a ring. All the blowthrough signaled from the oil fill cap.
Old Jun 16, 2009 | 08:50 PM
dmorenoprieto's Avatar
That sucks man! Good luck!
Old Jun 16, 2009 | 08:59 PM
ramtime's Avatar
that sucks. I would try pulling the plugs and cranking it over. Then wd40 the crap out of it and put it back together. you may just have electrical issues. I did the same thing awhile ago and it started up the next day after I srayed her down.
Old Jun 16, 2009 | 09:50 PM
gary96360's Avatar
that got hydrolocked pretty easily lol. i drive slow in puddles that are like up to my doors so that problem wont happen to me
Old Jun 16, 2009 | 09:52 PM
Tofer's Avatar
Sponsor
try again ramtime.....
Old Jun 17, 2009 | 07:24 AM
okie81's Avatar
That sucks. I'm glad you were able to show the Nissan's you could still make it home though.
Old Jun 17, 2009 | 08:13 AM
Lumpy's Avatar
That really sucks dude...Like the others have said, at least you were not stranded and in need of a tow.
Old Jun 17, 2009 | 09:55 AM
ramtime's Avatar
Sorry, didn't see that one!
Old Jun 17, 2009 | 02:03 PM
jusfloorit's Avatar
Normally I do go into them slow but I didn't want to get stuck and have to be pulled out again by an Xterra that made it through.
True. At least I got to drive her home. That tow probably would have cost about $460. It's still a tease though. I can go out there right now and she'll start right up and idle. She lopes a lil bit, but with 3 cylinders, we're not embarking on any adventures any time soon.
What sucks is my now daily driver is a 12sec. Camaro that gets about 12mpg and runs on premium. Ouch.
Old Jun 17, 2009 | 02:50 PM
Plumbrbob's Avatar
that sucks jusfloorit really that is crappy
I hope you figured out from all this drama that full throttle haul @$$ into a water hole is a dum dum move that will always result in stall or hyrdo lock unless you have snorkle and rtv siliconed your dizzy cap.
It would of been better to creep and crawl in the hole then give it full gas at the worst you woudl of been stuck with a healthy motor and thats a easy fix a tug from a bud.
Old Jun 18, 2009 | 07:02 PM
jusfloorit's Avatar
MY LUCK JUST KEEPS GETTING BETTER!!!!
The trans. in my Camaro is taking a dump. It had a monster hole in the exhaust so 2 days ago, I ordered a $300 cat-back for it. I was gonna drive her untill I figured out what i'm gonna do with the Toy. Well yesterday, while driving home, she was driving a little rough. This morning I drive it and it definately felt weird. A vibration, kinda like a bad u-joint at the trans.
My shop calls me and tells me my exhaust is in so I drive over there and pick it up. Each time I drive her it gets worse. I figure i'll know better what's going on when I put the exhaust on. She'll be quieter and less shakey and I'll be able to hear what's going on.
I bolt up the new exhaust and now I can hear it. When you put it in gear it has a weird scuffing sound like a dictionary being slid down a hallway. Now it's starting to shift funny and sometimes when you put it in gear, it hits so hard that it stalls the car. And the vibration, which I thought was because of the big hole, is worse.
I can't win. I have a used 5sp. and all the parts to convert it except clutch kit, master, and slave cylinders (another $300). I could do the swap but with my luck that trans could be bad or will go bad.
Now i'm back to 0 working cars......
Old Sep 22, 2009 | 10:07 AM
Outsane's Avatar
maybe the "jusfloorit" isn't a good modo for you
Old Sep 22, 2009 | 10:37 AM
99SR5's Avatar
holy crap! well looks like a great opportunity for a 5VZ swap =)
Old Sep 22, 2009 | 11:33 AM
Dan.3's Avatar
wow!!!!! you guys are quick.
it took you a whole 3 months to come up with that? That was really funny.
Old Sep 28, 2009 | 11:32 PM
Quagland's Avatar
whats hydrolock lol im anoob
Old Sep 29, 2009 | 12:23 AM
fork's Avatar
this is one of many reasons i now avoid mud
Old Sep 29, 2009 | 12:51 AM
Matt90V6SR5's Avatar
Yeah my 4runner is my only vehicle so all that " fun " is not in my budget.I would need money to burn to off-road like that lol.
Old Sep 29, 2009 | 02:28 AM
MUNJUE's Avatar
whats hydrolock lol im anoob?
the engine cylinders filled with water, water dose not compress like air, the piston stops moving when it cannot compress the water, and the engine stop's,and it usually ends up with the conrod being bent,
