IFS in a 83
Old 12-10-2013, 10:38 AM
  #81
Ghettofab88's Avatar
This is cool!
I toyed around recently with ideas for building a smaller IFS Ultra4 buggy, but couldn't get around the cost of halfshafts. They're just so expensive, and the strength is somewhat unknown in relation to a solid axle. I'll be interested to see what you do for halfshafts.
Hydro assist should be rather easy. Just attach it to your swingset like you would a regular tie rod.
Good luck and keep us updated!
Kevo
Old 12-11-2013, 09:15 AM
  #82
R.DesJardin's Avatar
Originally Posted by Ghettofab88
This is cool!
Kevo
Yeah, I've got a couple twisted ideas swimming around in my head. Keeping in mind a lower horsepower motor (ie not a Chebby) and wheelin that does not require D60's.
Old 12-25-2013, 02:44 PM
  #83
Still tweaking on the design,
Need to decide on spindle units, thinking maybe unit bearings and Chevy calipers.
Ball joints or in lieu of like spherical bearings with misalignment spacers.
I mocked it up on a model of my frame, but still debating the mentioned. I need the outside parts finalized before I finish the arms so I get the widths right.
And then there is the steering. Thinking of hydraulic assist or full hydro.
Old 12-27-2013, 10:51 PM
  #84
ToyoTech559's Avatar
gonna be sweet to see what you do. be the 1st i have heard of someone actually doing and not just saying so lol.
side note. i just picked up a rail II and be installing it to my 88 v6 auto runner. any tips before i get this bad boy installed? instructions doesnt say where the wires are? am i just t tapping into the factory wiring? thanks
Old 12-28-2013, 04:32 AM
  #85
I have a pile of components right now and I think I have a plan. It's getting close to time to start cutting some steel. Some of the stuff I'll work out as I start to fab. Like a friend told me once "If you are just going to guess, don't take all day."
Old 01-21-2014, 01:37 PM
  #86
You can only draw so many CAD models before you say "Just Do It!" I always say "If you are going to guess don't take all day" and "Keep moving forward" time to get going on this. I'm the kind of guy to get at it and built a couple prototypes and to keep drawing stuff and still not be sure itf it will work.
So I sent CAD dxf's to get waterjet cut today. Time to start mocking stuff up in steel, I really need to check the geometry out with the CVs and axle shafts and steering knuckles. I've got something different planned for this part of the design. Wait for the photos.
Old 01-21-2014, 02:34 PM
  #87
RobotMoose's Avatar
Originally Posted by R.DesJardin
...Wait for the photos.
With baited breath!
Old 01-22-2014, 05:00 AM
  #88
A person needs heavier duty CV's ball joint and steering system?? ???????????????????? That isn't stuipid expensive!
Also a should add my disclaimer: While I have designed and built some pretty unique and innovative accessories for my Toyota, I in know way am delusional enough to guarantee this setup will work. But I want to try it.
Old 01-22-2014, 05:07 AM
  #89
Fossilized
Staff
dropzone's Avatar
Are you done yet? You must have had your coffee by now...fire up that cool machine of yours and crank this thing out
Old 02-02-2014, 07:59 AM
  #90
Almost bud, probably down to less than two years to go.
Prototype parts cut for the basic layout, started mocking stuff up a little. Still waiting on some purchased items to roll in and I need to machine a couple key parts. But the point is I am working on it. Material is 10ga steel as this will be what the most of the assembly will be made from, Yes it will have bracing/gussets! Come on man look at my bumpers nothing weak about that design. Right now I leaning to full hydro for steering using a double rod ram and a slider setup.
Old 02-21-2014, 02:50 PM
  #91
Well I picked up more parts from the waterjet supplier and then these came today.
This theory is getting serious fast.
Old 02-23-2014, 05:50 PM
  #92
Well here you go. Mock up, but can't say if this is the final layout.
Trying to get more A arm clearance with some crazy bends..........just trying stuff out.
Its just laying on top of the flat pattern for comparison.
Old 02-23-2014, 07:55 PM
  #93
morena67's Avatar
Suscribed...!!!
Old 03-17-2014, 04:29 PM
  #94
Been building misc parts. Here's pics of a new Tormach 15L SlantPRO CNC lathe making some adapters I need for this. (This part is still top secret)
I'm really needing to make a custom press brake die set for my hyd. press so I can make better bends in my a-arm plates. In the long term I am designing my own small 20ton press brake, I think? I will probably make it just to see if my design works. It will be a bench top type unit since it's just for bending plates with a 18" open width and a 6" throat depth opening.
Old 03-17-2014, 05:36 PM
  #95
Fossilized
Staff
dropzone's Avatar
You my friend have some very cool toys in your garage
Old 04-19-2014, 05:20 PM
  #96
87-SR5's Avatar
What about running a woodward steering system?
Very strong lots of angularity and extremely strong. Might want to look at them. Nice work by the way. I will be running Blazelands system on mine. Hopefully with CMD.
Old 08-14-2014, 06:09 PM
  #97
Still on this, I was crazy busy in June and moved back to my house in Washington state in July. Now the truck is in a larger enough shop to get some real work done and start mocking things up. I think that this will probably finish up next year after snow wheelin season, but if I can I'll try for this year. Just don't want the truck laid up after Nov. starts.
kawazx636
10-06-2021 03:03 PM
83yotastockR
11
11-10-2015 06:54 AM
Badlander
10-10-2015 08:05 PM
dirk89
10-01-2015 05:15 PM
JookUpVandetti
09-30-2015 08:58 AM
Quick Reply: IFS in a 83
