Paddle tires?
Old 03-27-2006, 08:09 PM
96runner's Avatar
Talking Paddle tires?
Has anyone here used paddle tires on their 4Runner? I go to Glamis and I'm thinking of looking for some. I'm thinking 31" paddles on 15X15" rims. Right now I have 31" Super Swamper TSL's I air down to 10#, I do good but I'd like to do better. Anyone know where I can find some for a good price? I'm in So. Cal.
Old 03-27-2006, 08:46 PM
Robinhood150's Avatar
10 lbs with super swampers? Go down to 1-5 pounds and you'll do exponentially better.
Old 03-27-2006, 10:00 PM
Mr. Bob's Avatar
Boggers and lockers if you dont have them already!!!!!!!!!
Old 03-28-2006, 06:33 AM
snap-on's Avatar
you better have bead locks if your gonna run that low else your gonna find yourself blowing beads left and right!
Old 03-28-2006, 08:48 AM
tc
tc's Avatar
You have enough power to spin paddles? (ie - supercharged 3.4?)
Old 03-28-2006, 09:01 AM
Blowing beads is certainly possible, so he should have a way to re-seat them. But if he drives sanely, he won't have a problem. 10 psi is pretty normal pressure for sand for street tires. 10psi for swampers is nothing, they won't hardly bulge.
Plus, swampers aren't the best for sand, too aggressive. They just dig and you don't go anywhere. ATs are better.
Old 03-29-2006, 10:53 PM
jsnby's Avatar
Old 03-31-2006, 12:03 AM
BajaRunner's Avatar
Wouldn't paddles be considered an agressive tire that digs too?
Old 03-31-2006, 03:07 AM
tc
tc's Avatar
That's why you need a ton of power, so they'll keep you skimming across the top. Look at the vehicles that run paddles - all really high power to weight ratiosvb
Old 03-31-2006, 09:12 AM
00Runner's Avatar
A padle tire has very few actual lugs. The rest of the tire is completely smooth allowing the tire to float and the lug to dig in and push.
Old 03-31-2006, 08:40 PM
BajaRunner's Avatar
yah!
Old 04-11-2006, 06:00 PM
norflaballer's Avatar
#1 - tl;dc
#2 - Super Swamper Vampires
#3 - Rims that have the dual pressure zones. one side is like street pressure, and other part is like 1-5 PSI... so u don't blow beads but have the low off road pressure
Old 04-11-2006, 06:42 PM
tc
tc's Avatar
Aren't Vampires the ATV tires?
Old 04-11-2006, 06:46 PM
idk? i saw a picture of just like the tread. they are bad ass... i could have sworn they where full size tires... cause i don't think interco makes ATV tires... but i could be wrong. it was on tthe same page as full sized ones so... idk
Old 12-19-2006, 11:30 AM
96runner's Avatar
Talking
I bought some Desert Track paddle tires size 14.50 X 15 on 15 X 10" rims from Sand Tires Unlimited. One word "AWESOME", aired down to 8# I went everywhere our sandrail went with no problems(except the big dunes behind Oldsmobile). I even made it up Oldsmobile (for those of you that are familiar with it). Not bad for a 96 2wd 4 cyl.:bigclap:
Old 12-19-2006, 11:43 AM
95_4MuddinSr5's Avatar
Interco does make atv tires and they real cool but you cant get the vamps in a big size unless you want 24" atv tires? i think price wise stick with swampers and air down and ride out!
Old 12-19-2006, 12:45 PM
norcalsvx's Avatar
http://www.sandtiresunlimited.com/sandtire1.html
good info on here
Old 12-19-2006, 03:39 PM
4Crawler's Avatar
I ran my old 33x15.50 Swampers at 1-2 psi (my gauge stopped at 2.5) and they were awesome, no bead loss either. Below 2 psi, the sidewalls would just start to wrinkle and that is when they started working good:
Only problem I had was not enough power with the 22RE to get them going.
http://www.4crawler.com/4x4/PismoBeach/index.shtml
1uzRunner
63
11-10-2018 03:58 PM
Williamemslie
14
10-05-2015 09:28 AM
AkitaDog
09-03-2015 09:01 PM
128keaton
09-03-2015 05:09 PM
matthew138
09-03-2015 08:21 AM
Quick Reply: Paddle tires?
