More under axle clearence
I have a 98 tacoma with 33's. I was wondering what brand of lift gives the best under axle clearence, or how to get more with out bigger tires or a sas. I want to keep my IFS. Thanks for any info.
I think the only way to increase the under axle lift would be to put bigger tires on....I may be wrong
From the way I see it, the axle is a straight tube that locks to the center of the wheel...there is no way that I can think of that will push it up unless you add bigger tires...On the front IFS maybe...
BTW Welcome to Yotatech..
I read all of the features and stuff but didn't quite understand.....does it offer any lift or does it somehow make travel greater?? Sorry if stupid question...
The only way to gain clearance under the rear axle is either to shave the axle, which will give you perhaps another inch, or to put on bigger tires.
ONLY 2 ways to gain clearance under the axles:
tire DIAMETER
-or-
portal type axles
So, taller tires are the only feasible way. Note that I am being very specific, not saying "bigger" tires. You can fit a taller tire if it's narrower.
If you've got 33's under a Taco, you already have some lift on there - gonna need A LOT more details before we can help you:
- Exactly what size tires do you have now?
- What rims? What's the backspacing?
- What lift?
tire DIAMETER
-or-
portal type axles
- What lift?
TheBFA
02-15-2020 06:55 AM
live4soccer7
05-11-2016 06:52 PM
JookUpVandetti
09-30-2015 08:58 AM
Cycles
09-29-2015 06:37 AM
Toys4parts
09-26-2015 01:56 PM
