Last edit by: IB Advertising
- Toyota Tundra Why is Frame Sqeaking<br>Guide to diagnose trouble and recommended solutions.
squeaking bed
squeaking bed
SIGh.. eversince i got rear aals, ive been having trouble with them. Last time it was due to the fact that the shop did not BOLT on the lower shocks.. and now.. my bed sqeaks everytime i drive it.. when im just on the road it squeaks!! like an old door that needs to be WD40ed-which i tried to do with the leaf springs and everything else under the bed. Any idea guys? This only happens on the driver side of the bed! For example,...when i push down on the bed (drivers side.) it squeaks!!!! could it be the stock shocks that i need to change? the aals are only 1.5 in. Should i drench it with more WD40? heeellllppp.. my girlfriend is complaining that i should have it checked up in case if its something big! and shes complaining soo much that its getting on my nerves!!ive checked the bolts and they are all tight!
Read this - Squeeky Springs
Originally Posted by Bob_98SR5
you might just want to pull over and rent a room instead of using the cab
bob
bob
Anyway.. i just sprayed some WD40 while at work.. drenched the leafs.. but they still squeaked.. after work.. i drove it to my girlfriends house.. and no more squeaks!!- Probably needed to some movement for the grease to get into tight spaces!
bob
bob
Originally Posted by slyang1012
Thans BOB.. But if i ever needed to do "that" I would first have to replace my shocks!!!
justdifferentials
14
06-11-2017 08:36 PM
FS[MidAtl]: 2000 Tundra (Parting out) Pennsylvania
ToyotaMD
11-09-2015 11:53 AM
87SR5justin
09-29-2015 02:50 PM
