Update On Buying A Used 2000 4runner - Rear Axle Leaks!!
So, I had the Toyota place check out the 2000 v6 4wd 4runner with 138K and it has rear axle leaks on both sides. They told me it would cost about $750 to fix it, because they are going to replace the (bearings, too?). But, if they fix it, is it going to be a reoccuring problem? Are all 3rd generation 4runners prone to this problem or are some years better than others? Should I offer to take it as is and offer $10,000? He's asking $11,000. Everything else checks out fine.
Jay
Jay
as i recall from previous posts that you could find by searching, the axle seal itself costs about $20 and you can do the first in about 1-2 hours and second in about 30-45 minutes
https://www.yotatech.com/forums/show...661#post965661
write-up
from what i see it involves bleeding brakes also... maybe 150-200 for everythign including new rear brakes?
edit: i suppose take the quote and the offer and then do it yourself... dep on your tools, area to work, and what-not...
write-up
Yeah those seals are real easy to replace, i did one on my buddys 02 4runner and i think the seal was like 10 bucks at carquest and took about and hour for every thing.
I would deffenatly talk him down in price for that reason and tell him how much they quoted u at toyota to fix it.
No matter which route you take, don't forget to figure out why it happened - or it may happen again with the new seals. The most likely culprit is the diff breather; check for proper operation (cap should lift easily and the passage should be clear). Considering the cost, you should just replace it and/or do the diff breather mod if you plan to wheel it at all.
Thanks for the advice, I should have done a search in the first place - there were tons of threads on the subject. But, I'll probably just have them do it, since buying and modifying a press to remove the wheel bearings doesn't sound like fun and I don't own any tools. I'll check the diff breather, too. Also, I ended up paying $11 grand for it, so I hope nothing else goes bad.
You don't need a press to replace the seals. It's actually a pretty easy job. My buddy Scott just did one of his seals for the first time the other day and he was out wheeling again in a couple days. The hardest part is probably replacing and bleeding the brakes. Save some money, buy some tools, and do the job if you have time. The R&R instructions are out there to walk you through it. Check the tech section out.
lets be careful here. To replace the inner axle seal (the oil seal) does not require a press. Anecdotally, replacing the inner seal solves 80% of the leaks here on Yotatech (that's based on me and my reading)
However, replacing the outer seal (and bearings, as stated the dealer wants to do) requires a press. Well, I don't know if it requires it - but the tech articles I've read state to press the rear axle shaft back into the bearing/retainer. But, since I haven't performed this task - perhaps the press isn't truly necessary.
personally I replaced the inner seal using a borrowed puller and a large socket. This did not solve my leak. I ended up having a shop replace the bearings and outer seal. This repair has lasted for a few years.
You'll find stories of people with deflected axle shafts causing leaks. I believe the early ABS equipped runners have the most issues with leaks (96/97).
Good luck.
Good luck.
6th Gear
19
12-10-2019 07:31 AM
