Tensioner pulley, I cant get it to loosen up!
Old 05-10-2008, 08:30 PM
312necro213's Avatar
Okay so I got it all taken apart and I need help with the tensioner pulley I cant get it to loosen up, any help is appreciated I have a picture attached of the little piston thing I can't get to loosen.
Old 05-10-2008, 09:14 PM
fillsrunner4's Avatar
Dude you have to remove the entire unit. That piston will not come out like that and should not. it has two bolts below. Losen evenly and the entire unit will come out as one. You will need a press to compress the "piston" piece back to were it belongs. I sujest a whole new one. It will come with all you need. Read a manual before you look to do this agian.
Old 05-10-2008, 09:28 PM
Elvota's Avatar
Fillsrunner4 is right (as usual)
This tool, or similar... will also work if you can't remove the tensioner:
http://buy1.snapon.com/catalog/item....&group_ID=1552
Old 05-10-2008, 09:42 PM
Ive got my wrong moments too
kawazx636
10-06-2021 03:03 PM
Dale Johnston
11
10-31-2015 10:22 PM
moparbay
10-06-2015 09:24 AM
Obmi
10-04-2015 11:30 AM
EVars
09-29-2015 02:06 PM
Quick Reply: Tensioner pulley, I cant get it to loosen up!
