Question on replacement spare wheel
I have a 2002 Tacoma 4x4 and bought another wheel as a second spare for my truck.
The new spare seems to fit, however the lug bolts for my aluminum wheels seem to fit funny with this new spare? They also fit funny with my stock spare? I think it is the fact that the lug nuts are for my aluminum wheel with the thicker hole in the rim?
The lug nuts do tighten up well on the new, second spare and do not bottom out. My brother said I should get some steel wheel lug bolts?
What do you think, do these spares look pretty similar?
The two photos on the left are of the new, second spare and the one on the far right is the stock spare. Notice the hole in the new, second spare is thinner than the stock spare and also the new, second spare center hole is not a smooth hole, it is notched?
Thanks
Bill
Thanks
Bill
Here is another photo of the new, second spare with the lug nuts on it,on the left. Is this ok? The nuts tighten down well?
Then on the right is the stock spare wheel.
Thanks
Bill
Thanks
Bill
They sell different style lug nuts! Im not sure what the real issue is but I remember using the wrong lug nuts and almost having a wheel fall off because of it!
Have you driven around with it on? Does it make weird noises or vibrations? If not I dont think there is any issue!
I think there are shorter lug nuts for the steel wheels. My brother said the longer lug nuts I have could bottom out, but that is not my case.
Yes, it is just a spare, but I want to make sure it will work. I got it for going in Nevada or way back in the back country where I would not want to drive 100 plus miles on a rough road just to replace a tire, if I ruin one.
Thanks
Bill
Thanks
Bill
Thanks
Bill
Thanks
Bill
I would imagine your fine. If your afraid of tire issues get better more reliable tires for the abuse you put them through!
IE people do the BAJA 1000 on BFGs and similar with way more power and higher speeds you wont see! Also abuse most tires dont see in a lifetime!
If you hear noises from the wheels or have massive vibration... Get off the road and it will be apparent if its the rims, via removing one bolt and seeing metal wear or disfigurement!
Thanks
Bill
I went and took my front wheel off and put the new spare on and it fits nice and tight and I took it for a drive and it is just fine.
Thanks
Bill
Thanks
Bill
when I bought American Racing steel wheels it was necessary to buy new lug nuts. The Original Equipment lug nuts were I believe the term is "lugcentric" while the new wheel's lug nuts were "hubcentric" or perhaps I have swapped the two around.
I thought it was just some malarkey to get me to spend some more money on lug nuts-but other shops have confirmed same scenario.
See a tire shop immediately. Someone who knows more than us Internet posters-an expert with facts, not just one of us with opinions.
This could be a catastrophic failure- particularly at high speeds.
The picture #9 to me does not appear that the lug nut is properly centered into the opening.
I am no expert- but please find one to be certain. I tend to err on the cautious side....Let us know if I am full of crap-that is how I learn....
MMA_Alex
25
04-18-2017 05:07 AM
Avenged
07-09-2015 07:55 AM
Jnkml
07-06-2015 01:20 PM
