New product announcement. Manual control for your automatic transmission.
Old 07-05-2006, 05:26 AM
BrettM's Avatar
(Cross-posted with Corey's permission)
With the flip of a switch you can switch from your normal auto controlled by the ECU to full manual control where you control every shift and torque convertor lockup. Shifting is done through 2 momentary inputs providing countless options for shifting including pushbuttons and paddle shifting
Pricing starts at $130
A few more details and website linked in the post in the vendor section: https://www.yotatech.com/forums/showthread.php?t=89500
Brett
brett@AWshifting.com
Old 07-05-2006, 06:54 AM
KyleT's Avatar
does it keep it from doing the annoying downshifting on the highway every 5 seconds???
Old 07-05-2006, 07:01 AM
BrettM's Avatar
Absolutely. When in manual mode it will not shift until told to shift.
From my FAQ page:
Does it really give total control? When I put it in 3rd, will it go to 2nd and 1st as I slow down?
When in the manual mode, it gives FULL control. The transmission will go only to the gear you select and will remain there until you select another or go back to auto.
Old 07-05-2006, 11:44 AM
Tacoma Dude's Avatar
I wonder how this will work with superchargers?
An auto tranny will require specific work done because of the "luxury" shifting. Will this be a shortcut around that?
EDIT:
I'm also curious about reverse. Will this require shutting down the manual and reverting back to auto?
How does this affect the life of the auto transmission? How about the transmission fluid?
Old 07-05-2006, 12:09 PM
Rock Slide's Avatar
That sounds cool.
Let's see who's going to put one in their 4R.
Old 07-05-2006, 12:49 PM
midiwall's Avatar
From his FAQ:
Do I still need the factory floor shifter?
Yes. This shifter is only electronic and has no provisions to control the manual selection of park, reverse, neutral or drive. The controller can remain on in the other positions with no harm, but only controls the transmission in the drive positions.
Old 07-05-2006, 01:52 PM
neliconcept's Avatar
Id really like to do this but.. I think a kit needs to be sent to someone for free who is willing to install this for everyone else to hear about kinks and such. I do like the sound of paddle shifters.
Old 07-05-2006, 01:54 PM
Originally Posted by midiwall
From his FAQ:
Thanks for pointing that out. I read it but didn't make the connection
Old 07-05-2006, 03:22 PM
881stGenRunner's Avatar
I agree, but i still doubt i would be able to get one even tho i really want one
Old 07-05-2006, 03:44 PM
profuse007's Avatar
what kind of wiring does it required?
Old 07-05-2006, 03:50 PM
midiwall's Avatar
(this is gonna get confusing with two threads...)
I'm betting that Brett's tapped into the tranny ECU. That would make for a "simple" install in that you'd just have to tap the wires to the solenoids, then insert a switch into the circuit for handling TC lockup. Past that, you'd mount the LEDs and you're set.
So... 5 wires for the LEDs; 1 wire each for UP and DOWN; 2 wires for the TC intercept; and a ground.
Old 07-05-2006, 05:16 PM
BrettM's Avatar
midiwall is pretty close. Quick splice connectors are included and a few wires are hooked up to the ECU, all this can be done in under 5 minutes with just a pair of pliers. Then it's a matter of mounting whatever shifter, switches and LEDs you have selected.
HookahRoo
07-20-2015 07:06 PM
rushw
07-18-2015 01:46 PM
Poncho0206
07-10-2015 06:21 PM
shar
07-09-2015 12:38 PM
Quick Reply: New product announcement. Manual control for your automatic transmission.
