LED dash light color opinion (post pix if u have them)
#41
ok so im new to fourms been reading about this LED dash mod since last night. i just wanted to know exactly how many #74 bulbs i need and how many #194 bulbs do i need if i wanted to change the dashboard, the unit beside it (ac, and all that stuff) , the key ring, ..the drive shifter at the bottom...and the left pannel that rolls down ur windows and stuff..thanks!
#42
For the gauge cluster: Three #24
Key Ring: One #74
Cig Lighter: One #74
Ash Tray: One #74
Shifter: One #74
Glove Box:: One #74
Map Lights: Two Ba9s
HVAC Controls & Rear Window Switch: Two Type A & Three Type B Neo-Wedges
Middle & Rear Dome Lights: http://www. oznium. com/thin-led-domelight it's the 2.0" x 2.0"
You can get all those at:
www. v-leds. com
www. autolumination. com
For more info check out this thread: http://www. toyota-4runner. org/showthread. php?s=&threadid=35104&perpage=15&highlight=lightin
g&pagenumber=1
Keep in mind that this is an '02 4runner SR5 2X2. You didn't say what kind of car you had....
Good luck!
J
#43
my bad for not mentioning what car i have
its a '99 4runner sr5 2x2...soo im guessin same parts ?
anyways..thanks for the quick reply...lol that was pretty fast . didnt expect a legit reply before i went to bed.
#44
eh, what can I say, I have no life. haha.
But no, this is what another member emailed me directly. Idk if the parts are exactly the same since a 99 is a 2nd generation and mine is a 3rd but it should be pretty close.
#45
thanks EMTjermey...another question..this is my first time doing any sort of mod this car. how long do you think it might take me? from begining to end? so i know my time frame so i can get to work or school without reassembling?
#46
Well considering i ed mine up 20 minutes into it, its hard to say. I've heard anywhere from 45 mins-2 hours depending on your experience with cars. I'm just gonna have my mechanic do the gauge cluster. I really don't need to be breaking things up in there. It'll end up like my girlfriend's POS chevy. (Her speedometer and tachometer are out- the car is 3 years old). haha
#47
yea ive never had experience with cars, but i got the basic stuff that my dad taught me and stuff i learned over the years..im only 19 too, so do you think i should mess with the gauge cluster?
#48
My experience with the door controls [1994 truck] is that you really can't get to the lamps that illuminate the switches they seem to be part of the switch itself.
If I ever get a second set of switches I may try pulling them apart to find out but they are just too rare [2dr] up here these days to chance it.
#49
Location: Where it always works if you work it, in Sunny Selinsgrove, PA
#50
https://www.yotatech.com/forums/f131...ll-how-177866/
#53
Sup man, here's exactly what you'll need for the LED interior conversion:
Key Ring: One #74
Ash Tray: One #74
Shifter: One #74
Glove Box:: One #74
www. v-leds. com
g&pagenumber=1
Good luck!
J
Key Ring: One #74
Ash Tray: One #74
Shifter: One #74
Glove Box:: One #74
www. v-leds. com
g&pagenumber=1
Good luck!
J
what do you mean when u say "HVAC Controls & Rear Window Switch: Two Type A & Three Type B Neo-Wedges" cant seem to find those on autolumination.com can u show me way? thanks
#56
I would recommend going with the Tri-Power 3 LED bulbs from www.autolumination.com. I have them behind my gauges and there are virtually no hotspots whatsoever. They are really brights and they do a great job of spreading the light.
#57
Well i took my dash apart and took out the stock lights behind the gauges. But the base of the stock light is a lot bigger than the tri-power. I ended up putting those as my signals and behind my climate controls. Now i just need a bigger based bulb.
#58
If that is the case then the bulbs you need are the #194. Many of the older 4th generation 4runners use the #194 instead of the #74 behind the gauges. Autolumination sells the #194's as well. I would recommend getting the 5 LED matrix bulbs because they spread light in all directions and there shouldn't be any hotspots. I hope this helps!
#59
how did you do your A/C cluster? i've already done my main guage cluster but the back of my A/C lights are covered in orange filter paper. i tried scratching it off with a knife but i ended up goin right through and messing up the icons. also, what color were your interior lights before you changed them out?
ashersullivan88yota
01-18-2022 05:37 PM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
Johntom240
7
07-13-2015 12:18 AM
