Hesitation ( I searched )
Old 11-30-2006, 01:02 PM
jla123's Avatar
99 runner, 3.4L hesitates off the line, then has good pickup/response. Replaced fuel filter, TPS sensor, new plugs not wires though, cleaned throttle body, cleaned K N air filter. Would dirty MAF cause this? Coils? Throttle cable seems tight. Any other suggestions? Thanks.
Old 11-30-2006, 01:10 PM
Elton's Avatar
Originally Posted by jla123
k&n air filter. Would dirty MAF cause this
gotta love those filters clean the maf sensor also have you reoiled it ?
Old 11-30-2006, 05:27 PM
jla123's Avatar
yes i oiled the filter. ill clean MAF too.
Old 11-30-2006, 05:41 PM
rimpainter.com's Avatar
Can you describe the hesitation a bit more? Is it an AT or MT?
Old 11-30-2006, 08:18 PM
jla123's Avatar
its an automatic. when I press the gas pedal at a stop or when coasting slowly it feels like the throttle almost jerks, like the engine tries to catch up. you hear the engine rev for a split second then it then it goes. this only happens at a dead stop or coasting very slowly. even when i had the engine running and opened the throttle by hand you can notice as soon as you open the throttle there is immediate hesitation, but then it responds normal. if you very slowly gradually accelerate its not noticeable. thanks for any help.
Old 11-30-2006, 08:24 PM
YotaFun's Avatar
I notice a slight hesitation in my 97' but always thought it was normal...
I guess I always thought that it just needed it's time to calculate that oyu actually have the pedal to the floor...
Never a real problem for me...
Wish I had a Manual trans though...
An Automatic always makes hesitations like that worse
(same was in my 95' olds..)
Old 12-01-2006, 06:37 AM
jla123's Avatar
I have had a 2000 Taco with same engine and this was not an issue. The Taco would jump as soon as you touched the gas pedal.
Old 12-01-2006, 07:32 AM
ugadawg95's Avatar
I just had a similar issue...it was the plug wires. Since I replaced them, I have had no issues. If they are the original wires...they need to be replaced. When I pulled the boot off of #4, the metal contact stayed on the plug. I had to get some looooog needle nose to get the connector off. That was the cause of the problem I had. The code even indicated #4 was causing the CEL.
Old 12-01-2006, 08:04 AM
sdstud212001's Avatar
Are there any codes that need to be pulled? (check engine light on?)
Old 12-01-2006, 08:58 AM
YotaFun's Avatar
I am replacing my plugs soon... I guess I will look into some wires too...
Old 12-01-2006, 10:18 AM
Have you checked the fluid level in the AT?
Old 12-01-2006, 11:48 AM
jla123's Avatar
Thanks for all the help guys. I'll replace the wires, needs to be done anyways. I do not have a CEL on. Have not check AT fluid.
I have a completely new issue today!! I was turning left at about 5-10 MPH and the truck cuts off. No power steering, no power brakes, radio is still on and didn't cut off, CEL, Battery, dash lights on. Put it in Park and takes two tries to start then runs fine. Had starter replaced 2-3 weeks ago, and battery replaced 5-6 months ago. Now I'm freaked out because it was impossible to turn and impossible to stop, if this happened when I was going faster it could have been bad.
Old 12-01-2006, 01:27 PM
That sounds like a relay or the ALT. The battery only starts the vehicle, the ALT takes it from there (under normal circumstances).
A2theK
09-30-2016 12:50 PM
Jason Webber
09-02-2015 03:30 AM
4runnerstalls
08-26-2015 11:13 PM
hmmhoyhoy
08-12-2015 10:33 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Quick Reply: Hesitation ( I searched )
