E-Brake Light
Old 11-27-2005, 01:24 PM
Swissdrums's Avatar
E-Brake Light
My e-brake light seems to come on in the cold weather when i am just getting the car moving. Even if the brake isnt and hasnt been on. Anyone know why?
And...i was in some snow this weekend, and the ABS was doing good, but after a while the ABS light remained on and ii had no more ABS brakes, they would just lock up, no crunching sound. but the light was on, even when i wasnt on the brakes, i parked the car for the night and light was off in the morn.
Thanks,
mike
Old 11-27-2005, 01:28 PM
ASU4runner's Avatar
Not sure about 2nd gen's.. but on my 96 the brake light will come on if your brake fluid is low. Check the brake fluid reservoir under the hood before you do anything else.
Or it could be a bad ABS sensor
Old 11-27-2005, 01:52 PM
NathanBERG's Avatar
Yep, 2nd gens do the same thing. Do what ASU4runner said first and then go form there.
Old 11-27-2005, 05:01 PM
89macrunner's Avatar
top off your fluids for a start
the ebrake light is also the idiot brake flulid light on most semi older toyos
Old 11-27-2005, 05:03 PM
Localmotion's Avatar
id spray a lot of water near the drums/calipers and see if that does the trick...it worked for me
Old 11-27-2005, 05:32 PM
tc
tc's Avatar
My 2nd gen's brake light was lit by a frozen caliper. Have no idea how it would know about that, so it must have some other things it looks at... check fluids, pads, ebrake adjustment
Old 11-27-2005, 05:39 PM
Dr.Feelgood's Avatar
Give the e-brake handle a push when it does it. Seen a lot of them where the handle doesn't like to stay in, especially when it gets cold and things start to get stiff. If it is, spray it with some Deep Creep or similar lube and work it in there.
Old 11-28-2005, 03:51 AM
Rick F.'s Avatar
Location: Far western Kentucky (transplanted from central PA)
The brake fluid needs to be right up to the line; not a centimeter lower. My '90 was notorious for that. Adding even 1 tsp extra, even when it looked like it was ropped off, would sometimes be enough to kick off the light.
Old 11-28-2005, 10:13 AM
da_bigg_wigg's Avatar
my lights been on for a few months now. the fluid is topped off. I checked the sensor-looking thing in the master cylinder resovoir, and it looked like a little bit of the amber-colored plasticky thinger (thats right, gettin' super techincal with y'all today...) was chipped off. not a huge amount, but enough that it looks like the wires might be a little exposed. no chance to hit up a scrap yard to find a replacement yet. on a side note, anyone know a good scrap yard in calgary, alberta? im new here, so i dont really know where to go yet...
Old 11-28-2005, 10:49 AM
Jays4Runnin's Avatar
Brake Fluid Sensor
In my 2nd gen, all i did was unplug the sensor on the resivoir. There must have been a short in the wire on mine
AkitaDog
09-01-2015 08:05 AM
yipyip45
08-06-2015 02:05 PM
priest16
15
08-06-2015 07:43 AM
PopsDad1
07-30-2015 02:21 PM
Odin
07-15-2015 09:28 PM
Quick Reply: E-Brake Light
