Do you run high RPM?
#41
i usually shift my 3ezv round 3500, if i really need to get up and go i push it to 4500.
If im pulling ill generally pull till about 4K and shift.
I am known to cruse (when towing) at 3500-4K though....
the auto in my 4 runner likes to push it all the way to 5+ befor shifing if your in it
#42
Originally Posted by snap-on
the auto in my 4 runner likes to push it all the way to 5+ beforE shifing if your in it
should not be any problems keeping it just below redline, just dont drive for a 1000mi with like that.
#44
Originally Posted by Bumpin' Yota
btw - is 6000rpm on 3.0 considered high? with 265,000 miles on the clock? My toy knows I love it! Of course the oil is usually changed every 2400 miles too....lol
#46
Originally Posted by celica
The rev limiter cuts in around 5500 rpm
#47
With the blower, my 3.4 makes the most torque around 3600 rpm. Yes I have seen redline plenty of times. This engine seems bullet proof if set up right. Notice this is dyno run number 50.
#48
The Toy's Supra motor has to be on e of the strongest engines out there in stock trim as even my friend's '97 laid down just over 700whp on the stock internals with just a better headgasket and ARP studs to hold the head down at 24psi pumping through a T66 turbo and ran low 10s in Phoenix with power everything,cruise and AC in tact and gets just over 30mpg at a steady 75mph on the highway.
#50
I used to regularly approach redline in my MR-2, but not in my 3.slow. Usually no higher than 4K is needed on acceleration, and I like to cruise at around 3K on the freeway. It's not a racecar, and I need it to last!
#51
Nope! I have an auto and it lacks any kind of revv limiter. Redlining it to 5800rpm is no problem. In neutral I have accidentally revved it to 6500...I thought it was in gear and punched it...
Matt
#52
My 92 has the limiter at around 5500-5800 but I am a standard. Does this mean that the auto does not have the limiter?
Matt
Matt
#55
not sure how to make a new thread, question about 22re redline
what is the actual redline of the stock 22re. i already know the peak hp rpm, i just want to know the redline.
#56
#58
NO it does not hurt the motor to rev to 5K+
YES there is a factory rev limit set at 5600 i believe
YES obviously its not good for a engine to redline all the time
you cannot just ask such a basic and simple mechanical question as "does it hurt it to redline"? Sorry that is something my fiance would ask no offense
how far a engine can rev, hold together at RPMs etc is based on many different variables.....head valvetrain componatry is key and how it is capable of holding revs - what the springs are like etc. The factory puts in Factory rev limits so you can not overrev lets say and drop a valve. I have not experience ANY valve float up the the limiter (bouncing off it actually), so I surmise that Toyota has enough spring pressure in the stock springs to be good for what
I have not delved into the the 5VZ-FE engine yet. Anyone know what the interals are? Forged pistons? Powdered rods? There is not much info out there like there is for my supra and mustang
Poncho0206
07-10-2015 06:21 PM
88runnergomas
07-09-2015 01:12 PM
