Damp carpet - front driver's side
Old 06-11-2015, 12:57 PM
aowRS's Avatar
I've noticed a dark area for some time in the carpet right next to the door sill. I thought it may have been an old stain from spilled coffee - but it's definately damp to the touch.
Any thoughts?
- I purchased the truck new - it now has 331,000 miles
- I occasionally add some refrigerant to keep the A/C cool
- The A/C does drip condensate on the ground
- Coolant level is fine
- No sunroof
- Original windshield
- No accidents
Andreas
Old 06-11-2015, 01:15 PM
aamsowens's Avatar
Check your clutch fluid my 87 leaked there
Old 06-11-2015, 01:41 PM
aowRS's Avatar
It's an automatic.
Andreas
Old 06-12-2015, 12:02 AM
wyoming9's Avatar
Red face
If it is a Automatic it is either brake fluid or water coming in .
Losing any brake fluid??
leak in the windshield seal ??
Hole in the floor some place behind the left front wheel??
A really bad engine oil leak I am sure you would notice That is migrating into the cab
Old 06-12-2015, 02:50 AM
aowRS's Avatar
It's not brake fluid and the windshield & seal are original. After finding a few other threads describing a similar issue, I will take a closer look at the large firewall grommet. I've sent various wires through it over the years for lights, sensors, etc., so it could very well be the culprit.
Andreas
Old 06-12-2015, 06:16 AM
aowRS's Avatar
I believe I may have solved the mystery. This morning I removed the sill cover and then folded the carpet back towards the shifter. After vacuuming a bit I noticed staining in the area of the footrest. This staining continued to the floorboard and along the side, where the carpet & padding was damp.
I took a closer look and was surprised to see a Y-shaped crack in the sheet metal of the foot rest. Shining a light on the crack made it very visible in the wheel well. My theory is that the foot rest fatigued & cracked (it flexes very easy) which then led to the fender well underseal cracking. Driving in the rain would keep that area hosed down with water. Furthermore, I tend to run the truck through a touchless car wash with chassis spray quite often...
I have made a cardboard template and will create a plate from 1/8" aluminum to cover the entire footrest and prevent further flexing.
Instead of trying to remove the entire carpet, I'll try to clean it in place and leave it folded up for a week or so.
Andreas
Old 06-12-2015, 09:00 AM
aowRS's Avatar
Almost done. I created a reinforcement from 1/8" aluminum plate, treated the rust, and then attached the plate using some stainless steel buttonhead bolts, washers, and lock nuts. I bedded the plate in OSI polyurethane construction adhesive.
Bush league, but hopefully solved.
Andreas
Old 06-12-2015, 12:32 PM
wyoming9's Avatar
Red face
Hole behind the left front tire Who would have ever thought??
It Does not hurt to put something on the outside as well
Unless you don`t drive in the snow.
Old 06-12-2015, 12:42 PM
aowRS's Avatar
You called it. I did apply gutter sealant to the area around the crack (in the wheel well).
On the inside, some etch primer followed by a dusting of Dorado Gold (left over from a project)
Andreas
Old 06-12-2015, 02:05 PM
Rock Slide's Avatar
Glad you found it.
You were right to go towards the firewall grommet...that has caught many by surprise.
Old 06-12-2015, 02:21 PM
aowRS's Avatar
Originally Posted by Rock Slide
Glad you found it.
Since everything was dusty under there, I looked for any signs of water running down from either the grommet or the wires that go through it. Everything seemed dry.
I'll keep an eye on it and update this thread with my findings in a few weeks (or months).
Andreas
Old 06-12-2015, 02:53 PM
PODrs's Avatar
Talking Cracked floorboard
Old 06-12-2015, 03:16 PM
avalonracing's Avatar
As always, nicely done.
Old 07-07-2015, 10:36 AM
pwgarcia's Avatar
Hole in wheel well going thru to drivers foot rest
I have this same exact prob with my 04 Toyo Tacoma Dbl Cab. Has 138,000 mi and I intend to get much more. Thanks for this awesome post as I intend to try a similar fix. THANK YOU!!
Old 07-07-2015, 10:46 AM
aowRS's Avatar
The sheet metal of your footrest cracked as well?
For the record, my carpet & padding have remained dry, despite a few carwashes, and numerous drives in torrential downpours.
Andreas
Old 07-07-2015, 11:13 AM
pwgarcia's Avatar
Andreas
I'm not exactly sure of the extent at this time. This weekend I'll be pulling back the carpet to view the damage. All I know right now is that I can push my finger thru the hole in the wheel well and push the foot rest.
Old 07-07-2015, 11:56 PM
wyoming9's Avatar
Red face
Sounds like a bit more then a crack.
We want to see pictures of this!!
Old 07-08-2015, 04:51 PM
aowRS's Avatar
Damn right!
Andreas
Old 05-29-2017, 01:20 AM
aowRS's Avatar
It's been two years since my ghetto repair and the carpet has remained dry. Ghetto repairs FTW.
Andreas
lledwod
08-30-2016 01:03 PM
09-04-2015 09:27 AM
87blyota
07-08-2015 09:16 AM
MTLroadierunner
07-06-2015 12:17 PM
coryc85
07-06-2015 04:07 AM
Quick Reply: Damp carpet - front driver's side
