2009 taco trd springs fit 3rd gen 4runner in front
Old 09-16-2011, 10:46 AM
drkblu4runner's Avatar
3RD GEN "1997"
I NEED A LITTLE MORE LIFT AND A FRIEND IS WILLING TO GIVE ME HIS 2009 TACOMA FRONT SPRINGS, WILL THIS WORK AND GIVE LIFT?
THIS MAY BE A DUMB QUESTION HOWEVER I FIGURED IT MIGHT FIT SINCE TOYTECS PAGE SAYS
Eibach front coil spring kit (set of 2) for:
95-04 Tacoma = 3" lift
96-02 4Runner 3" lift
05-10 Tacoma 03-10 4Runner and FJ 1.6" lift
Old 09-16-2011, 01:57 PM
dubbsbetty's Avatar
Cut and dry version, not really. It would take some serious modification to make it work. The second gen uses torsion bars whereas the 3rd gens(runners/tacos) use a rack pinion steering set-up. Now a puck lift may fit the coils in the back of a 2nd gen runner from a taco, trying that set up with a 4'' lift right now. Not sure about the coil buckets being the same dimensions though
Old 09-16-2011, 03:53 PM
Arrow
you are correct
my title is wrong tho i meant 3rd gen 1997.... im not that much of a noob, come on
Old 09-17-2011, 01:38 AM
anyone???? i cant find anything anyone.. seen tundra trds but not newer tacomas
this shows same spring fitting all..
http://www.toyteclifts.com/index.php...mart&Itemid=72
Old 09-17-2011, 05:42 AM
KZN185W's Avatar
yes, it will fit. someone has used a 4th gen 4Runner front coils in a 3rd gen 4Runner front. it's bit stiffer compared to the coils fro the 3rd gen 4Runner because the 4th gen is a bit heavier than the 3rd gen
Old 09-18-2011, 11:59 AM
ok thankks ill give it a try. any idea of how much lift (i have the 3rz)
Old 09-19-2011, 05:41 AM
KZN185W's Avatar
sorry, can't remember
Old 09-27-2011, 06:43 PM
installed today and it gave me 2-2.5in of lift. i also have 1.5in thick spacer on oem shocks. had to grind the uca
Old 09-27-2011, 06:57 PM
Doug18's Avatar
Were they stock 4th gen front coils?
Old 09-27-2011, 10:04 PM
they were stock TRD. however i think one side might be higher then the other by half inch or less..... i remember reading that some coils have a left and right.. doesnt bother me as long as it alignment isn't effected much
AustinTaco
08-22-2022 10:45 AM
Niameyrider
06-25-2015 05:50 AM
infinityisfive
06-16-2015 06:51 PM
westbound
06-07-2002 03:30 PM
Gene
19
06-03-2002 07:07 PM
Quick Reply: 2009 taco trd springs fit 3rd gen 4runner in front
