'00 4Runner Tailgate window won't work
Old 08-01-2009, 06:06 AM
stangman39's Avatar
Morning all!
Was all packed up and ready to leave for the beach yesterday afternoon. When I got home from work I rolled dropped the rear tailgate window a few inches to keep things cooler. Loaded everything up...was rolling out the drive and had the AC on and tried to roll up the rear window. Nope...nothing...switch on the dash wasn't doing anything. Tried to bring it down with the remote and it went down just fine. I didn't have time to look at much but did look for fuses but didn't see any. Swapped all the luggage outta the 4Runner and into my g/fs Honda and we made the trip to the beach in her car.
So...any thoughts? If the window goes down with the remote I'd assume the more is ok. Did the switch on the dash go bad? Seems odds to me that it would just go south w/o any warning. What is the best way for me to get the window back up and if I need to, how do I get access to the window or the back gate panel off?
Thanks!
Old 08-01-2009, 06:23 AM
Elton's Avatar
you didn't accidentally hit the window lock button did you?
Old 08-01-2009, 11:59 AM
stangman39's Avatar
Hmm...I don't think so. If I accidentially hit the button would the front windows still roll down from the drive door switches? I know I did test the driver (and pretty sure the pass) front windows and they both worked.
So..that window lock button locks the tailgate window too?
Old 08-01-2009, 03:14 PM
stangman39's Avatar
I won't be back at the car till Wednesday so I can't test it. I know I did roll down the drive window...so it sounds like if the lock is on I shouldn't have been able to roll make any windows go down.
Old 08-01-2009, 03:21 PM
stangman39's Avatar
LOL...I didn't even realize I have a keyhole to put the key in and roll the window up and down!! I've never used that before and if I had known I would taken the truck on my trip!! I've had the truck 3 years!! Boy do I feel stupid...
Old 08-01-2009, 04:38 PM
Ironmike4x4's Avatar
Don't feel bad, I did the same thing. I had mine for 5 years until someone made a post on here about it and the first thing I did was try it out. If it will roll up or down in any fashin with the remote or the key trick then you can elimnate the motor/regulator. If nothing works trying to roll it back up then I'd check the window motor w/ a test lamp and go from there. Post up the results and we can try to walk you through it.
Old 08-03-2009, 07:08 PM
Ron Helmuth's Avatar
this is fairly common. The rear window kind of loses it's memory, so you have to get it back up all the way. Even though you think it is all the way up, it may be a 1/2 inch short.
When the window memory is disrupted you also shouldn't be able to engage the rear defrost or the rear wiper. If you can do those but still not make the back end window operate from the inside dash switch you may have a different issue.
As suggested, make the window go down, using the key switch on the back end-then go all the way up. This will reset the memory.
Let us know.....this is how everyone learns from one another.
Old 08-12-2009, 01:58 PM
stangman39's Avatar
LOL...stupid me...somehow me or the g/f hit the window lock button!! On mine..when the lock button is down only thing that works is the driver window button!!
glad it was that easy!
Old 08-12-2009, 02:32 PM
Elton's Avatar
aha glad you figured it out and it didn't cost you money
Old 09-09-2009, 12:00 PM
lucifer28's Avatar
Question for you guys... I am trying to make the rear window roll down on my 98 with my after market alarm, does anyone have the wiring info for the rear window? Otherwise i can just go in and test the wiring but was hoping someone had the wire colors
voiddweller
19
05-02-2016 09:10 PM
Cesarl74
04-23-2016 06:07 PM
gog1968
06-22-2015 05:55 AM
williemon
06-21-2002 01:32 PM
Quick Reply: '00 4Runner Tailgate window won't work
