K91776’s ‘87 4Runner build
Old 06-27-2018, 12:50 PM
K91776's Avatar
Does anyone have any recommendations on a new starter? What company is the best to buy from?
Old 06-27-2018, 02:56 PM
old87yota's Avatar
Originally Posted by K91776
Someone please tell me if what I see is normal or not. It looks like hell and filled with dielectric grease.
The Diagnostic port grease is normal. The grease is one Toyota's ways to keep the corrosion down on the connector terminals.
Before you get too far, how do you know the starter is bad? What did you test(s) did you do to confirm this? I just want to make sure you are not just buying parts and hoping it works.
The best starter to get would be either an OEM Denso (which I am pretty sure is discontinued by now) or a remanufactured Denso starter that has actually been remanufactured by Denso itself.
Many other aftermarket starters tend to fail really quickly compared to the OEM starter. I have seen several threads here where an aftermarket starter only lasted from bad right out of the box to a few years.
However, the most common cause of starter failure (at least for our starters) is the starter solenoid contacts that wear over time.
If you do not need your 4Runner right away, you could pull the starter and have a look at the contacts: https://www.yotatech.com/forums/f116...ct-fix-193101/
Old 08-23-2018, 06:24 PM
K91776's Avatar
Sorry it's been so long since I've posted, a dear friend and Co-worker killed himself and I've been doing a lot with the department and family so it has kept me really tied up. I hope soon I'll be able to get in the garage and be able to upload more content.
azdesertrunner83
08-10-2014 01:24 PM
mightymouse
39
09-24-2011 09:12 PM
Zack1983
18
09-11-2011 11:58 AM
9164RUNNER
30
08-11-2011 09:57 PM
Junkers88
03-27-2011 07:56 PM
Quick Reply: K91776’s ‘87 4Runner build
