Back from the Dead - Rolled 1989 Pickup Rebuild
Old Feb 11, 2017 | 06:17 PM
  #41
ianjadkins's Avatar
3.0 pan on the 3.4
Tight fit for the drill.
Placed a magnet to catch any shavings.
Tapped and plugged the oils dipstick hole.
Pinion pressed in.
3.4 baffle modified, 3.0 pickup tube on and 3.0 pan on. Bottom end buttoned up.
Old Feb 13, 2017 | 03:42 PM
  #42
ianjadkins's Avatar
Spare parts!
I still needed to find a airbox, downpipe, cat converter, O2 sensors, EVAP box and PS line to modify. Found a local Toyota parts wrecker. I bought 1/2 a 98 Tacoma 5spd. Has a long block 3.4, 5spd, t-case, front diff etc plus all the stuff I needed. The price was same for individual parts needed only, or take the whole thing and strip them myself. Can you guess what I did? I have a spare engine (long block)now at least.
Sold!
Stripped it down quickly
Cut the frame up and sent it for scrap. Now just need to finish striping the cab and it can get crushed too.
And then there were 2!
Old Feb 14, 2017 | 06:46 AM
  #43
Terrys87's Avatar
What is that truck in the back ground? One day I want to do a truck in that year or so. I like seeing those built as well.
Old Feb 14, 2017 | 07:39 PM
  #44
ianjadkins's Avatar
Found a 10k ohm 1/2 watt resistor in my tool box. Tach mod complete.
Old Feb 16, 2017 | 04:15 PM
  #45
ianjadkins's Avatar
Crossover pipe
Thanks to the insane amount on information on this site, and the stickys in the 3.4 swap section. I was able to build my own crossover pipe. I also studied photos of others, and was able to build mine quite easily. Everything has been In the glass beader to clean, now need to finish tig weld then paint. Fingers crossed it fits!
Old Feb 16, 2017 | 08:55 PM
  #46
space-junk's Avatar
getting work done! i like it.
Old Feb 28, 2017 | 01:48 PM
  #47
ianjadkins's Avatar
Bit of an update.
2015 TRD Sport Wheels w/ 285/70/17's. Used a 1.5" spacer to fit past control arm and tie-rod. Could have gotten away with 1" possibly. Turns out it is the perfect fit, don't stick out too far.
Old Mar 1, 2017 | 03:28 PM
  #48
mbomberz1's Avatar
Nice job getting the wheels mounted up. Looking good.
I am surprised you needed spacers on your truck to get the wheels fit up. What is the backspacing on those wheels, and width? I am about to purchase some 16x8 4" backspacing rims and did a test fit with some 16x9 4.5" backspacing and i had no clearance issues on my 88, at least nothing I noticed... maybe i should go back and double check again. I felt like I had at least an inch between the upper control arm!
Old Mar 1, 2017 | 05:44 PM
  #49
ianjadkins's Avatar
These Tacoma wheels are 7.5" wide and have a 5.5" back spacing, that's why the spacer is needed. If it were a stock tire size it may have fit, but with the 285/70R17 and no spacer this happens.
I am sure a 1" spacer would have been enough.
My winter rims are 16x7 Tacoma/4Runner wheels, I believe 4.5" backspacing w/265's and they are fine. You should be good to go.
16x7, 4.5" Backspacing w/ 265/75R16
Old Mar 3, 2017 | 06:32 PM
  #50
SgtSuprman's Avatar
Wow, that truck is literally back from the dead. I love what you have done with it. Looks good!
Old Mar 19, 2017 | 08:07 PM
  #51
ianjadkins's Avatar
New shoes
Too bad I had to give the new tire's back, they were not mine. Lol. Just on loan for a test fit. But guess what? I bought a set for myself!
2014 Tacoma Sport Wheels
Paired quite well with 315/70R17 BFG A/T tire's.
Old Mar 29, 2017 | 04:16 PM
  #52
ianjadkins's Avatar
Update
Been a while since I updated, the 3.4 is getting close, new crank seals, cam seals, valve cover gaskets, timing set, water pump. Basically all the stuff that is easier to change while its on the stand. Basically pulled everything off, cleaned, sand blasted some, glass beaded some, painted some, then re-assembled.
Too bad my camera sucks.
This is how i flipped the fuel lines
Old Mar 29, 2017 | 04:44 PM
  #53
ianjadkins's Avatar
Found this Rebco style box at the wreckers last fall, and since the weather is getting better, I thought I better go grab it. Needs some work on the underside, some of the cross members are getting a bit thin, but It will be good and strong when I am done.
Old Mar 29, 2017 | 05:26 PM
  #54
space-junk's Avatar
i have never seen box like that before. looks cool. can we get more pics?
Old Mar 29, 2017 | 05:37 PM
  #55
ianjadkins's Avatar
This is the only one I have from the auto wrecker I found it at. I can post more later. Right now it is sitting upside down on my floor waiting for repars so not too photogenic.
I found this forum about the company that built this box, looks like they went out of business long ago.
http://www.ifsja.org/forums/vb/showthread.php?t=81522
Google Toyota Loggerbox and you will find more of this style box. Not many, but a few. This style box was more common for forestry companies on 1 ton bush trucks than imports.
Old Mar 30, 2017 | 05:06 AM
  #56
chukarhunt's Avatar
This is excellent work! Love that you're fixing it up. My pickup was in an accident this winter so I have some front end work to do myself, but it isn't difficult. That bed box is awesome. Somebody rear ended the back of my truck and dented the bed, so I was debating a flat bed, but I like how this box looks. Keep up the good work!
Old Mar 30, 2017 | 06:37 AM
  #57
ianjadkins's Avatar
I have always liked this style of box so when I found this one I knew I had to get it. I could have put new box sides on the factory bed I have, but then I would be worried about denting it. The logger box is solid, could back into a tree and no damage. Also, I can easily add a headache rack, and a removable rear rack for boats, lumber, long cargo etc. This style box is easy to build mounts for jacks, tool boxes etc. I will post more pics when I get it on.
Old Mar 30, 2017 | 07:14 AM
  #58
magnet18's Avatar
probably way late to the party, but I would put some more solder on those holes to the right of the resistor. They look like a vibe failure waiting to happen. But I'm picky about my soldering.
Awesome work you're doing to that truck!
Old Mar 30, 2017 | 07:18 AM
  #59
ianjadkins's Avatar
Not to late at all, I am still waiting to order a few new parts before I preform the swap, so the tach is still sitting in a bag on the bench waiting. Good point on the solder, or lack of solder, I will have a closer look and repair as necessary. Thanks for the tip.
Old Mar 30, 2017 | 07:47 PM
  #60
space-junk's Avatar
Man, i really do love that bed. looks like itd be perfect to put jerry can holders on the back by the tailgate and a full size shovel on one side with a hi lift on the other side.
