Where to buy pins?
Where to buy pins?
Just like the title, where can I buy the pins for the harness connectors? More specifically, I need to add a pin (wire) to a main ECU harness (E5). Where can I buy the pins?
You are better off hitting a pick and pull and finding toyotas in there and cutting the plug out and using that. Unless you have good soldering skills you are begging for issues with bad connections.
A little bit of history: I bought a engine with complete ORS harness with all the extras needed. Only problem was, the harness was made for an 89 truck. Mine is a 92, so there were a few different wires that I had to repin or resplice. I just need to add the AC pin to the E5 connector of the main ECU.
pins
im sure i still have some around here from my swap. Email me tirogers@nmu.edu let me know how many you need (maybe a pic of one) and your address and i can get them in the mail for ya.
This thread is a couple weeks old but you can also get them from your toyota dealer. They are a little spendy at around $6 a piece but if you just need a few to get things done its not the end of the world.
runnermedic
13
09-21-2015 05:20 PM
