need help, 1990 3.0L to a 22re
Hey guys, I need a little help, my Toyota experience is very limited. I have a 1990 Pickup with a dead 3.0L and a 1993 parts truck with a 22RE, Will the 22RE bolt up to the Trans? I assume the ECU, the wire harness and motor mnts will have to be swapped I just don't know about the engine-trans bolt up, they are both manuals.
Thanks for any help
Thanks for any help
Thanks for any help
Thanks for any help
The trans is different between the engines
It can swapped but you will need to to move all the efi components and the wiring harness. It is a whole lot of work to end up with a 22re. Personally if I was going to go threw all that work I would look into swapping a newer 3rz(2.7) or a 5vz(3.4). These engines produce better power and get better mileage than the 3.0
MMA_Alex
25
04-18-2017 05:07 AM
r3dfish
54
05-16-2016 10:31 PM
WTB[MidWest]: Looking for 5spd harness, front axle- 1990 truck
dfarr67
07-30-2015 07:08 AM
