Correct sump for Lexus V8 & SAS
Hi guys, is this the right sump to use with Lexus V8 when SAS'ing.
Im currently in the process of putting a truck together, i have a motor from the LS400 and im going to SAS also. I've read you need the rear biased sump to help with clearance?
This sump is from a Soarer, is there a more rear biased sump as this looks quite central?
Cheers, Nik..
Cheers, Nik..
yea the one you want is from the soarer or sc400 rear sump . the tundra has the middle sump and as you know already the ls 400 has the front sump .
if you havent browsed this site already you may want to .. lots more info ..
http://www.lextreme.com/forums/
good luck and dont forget to take alot of pics , especially of the details .
Yota 3.0
243
10-08-2016 10:31 AM
JookUpVandetti
09-30-2015 08:58 AM
