just seafoamed my '91 RE, videos!
I put it into the break booster vacuum. Waited about 15 minutes. I also put some in the gas tank, as well as a little bit in the oil.
I'm not sure if this was happening before i seafoamed, but when i was revving it really high, i heard a grind sort of sound. Anyone ever have this?
I also heard a little backfire..what is that from?
Keep in mind, I dont think ive ever revved my baby that high, so i dont know if it would have happened before the seafoam treatment as well.
mine backfired when i did it too, you should have waited longer, like an hour or even more, i waited overnight, whew that was a smoky drive to work the next day lol...
well i still have some left..maybe tonight before i go to bed i'll seamfoam it overnight...You think that should make it even more effective?
I followed the 5 min instructions and I thought someone was going to call the firefighters...OMG was there a lot of smoke... I think maybe the more gunk there is the more it smokes?? There was soo much carbon build up in mine that I was pinging down the road with regular driving... After about 10 min sitting in the drive-way with it smoking up the houses and half the street I decided to take it for a spin and see if I could blow the smoke out....well it took a good 5 min of driving and a nice acceleration over 4,000 rpm that ended the smoke... It been driving better ever since
Dude that stuff is awesome. I put some in the brake booster vac line and waited five minutes, little smoke, no noticeable improvement. Then I drove to Vail, up and over through the Eisenhower Tunnel. Still same old same old 3.0.
Once I got there, I added more and let it sit over night. Dumped the rest in the oil and gas tank. Lit it up this morning and nearly died from smoke inhalation, it purrs in third gear up steep grades at 50 mph. I love it. Sounds like 175,000 miles not 230,000. Good stuff.
It's all smoke and mirrors...did it on my Jeep and it did not remove any valve carbon, I looked at them directly through the exhaust ports...before and after....puts on a great show though!
EXACTLY 15 minutes is way too short.. do it three times with one can (1/3 can at a time or twice at half a can).. but let it sit in there no less than one hour. the longer it sits the better
2-3 cans in the tank with about 4-6 gallons of gas and run it empty
THEN you can use one can through the intake at 1\3 or 1\2 can intervals. leave it in there no less than 1-2 hours. the longer the better
i dont put anything but oil in my crankcase.
we both gained roughly 2-4 mpg just after doing this.. smoother idle, better gas pedal response. i would do it every 20k miles.. if you have a lot of miles do it more often then phase out to every 20k miles. i drive about 35k miles a year and yeah i can tell a differeence
i have seafoamed 4 vehicles and have never seen more than a small poof of white smoke. i have applied using all 3 methods but no smoke show. what gives?
No idea what was wrong. The vid above does not even begine to show the smoke i had the other day when doing it. Half the block was smoke screened and i had more than one person come out to ask what was going on.
ashamsuddin
17
01-13-2023 03:17 AM
LittleUgly
15
01-02-2020 01:30 PM
hiluxinargentina
09-30-2015 11:12 PM
myotherrideisayoshi
09-29-2015 05:41 AM
