What PSi????
What PSi????
What PSi do you guys run your tyres at?? im doing 90% road driving and have got BFG Mud terrains 325/60 15's...need some advice on what to put in them??
325 60 15 = 30.4" so I would say run 35psi, but that is subjective. I mean my 33x12.5R15 indicate that it's 35psi max pressure, but there is no way I'd run that much due to the narrow stock alloy rims. I run 25 to 26 psi to maintain a flat footprint, But this also has a large impact on MPG.
Hope this helps!
Larry
Hope this helps!
Larry
I run mine at 27 psi front and rear. Seems to have the most even contact for the tread so that I don't wear out just the middle. Search the chalk method. Essentially the best way to tell is to draw a line on each tire with chalk. Drive a mile or two and you'll see where the wear is going to occur, and you can adjust the pressure accordingly.
Fred
89fourrunner
02-17-2016 06:52 AM
travisamorgan
09-02-2015 01:00 PM
