starter problem, please help!
i have a 91 toyota pick up 2wd automatic with the 22re motor, it would always fire right up but now it just quit, i have a brand new battery that was tried on other vehicles so i don't need it load tested, and i just got the starter checked and got some things replaced in it and it was directly tested and it works good, when i turn the key on all lights light up and everything is normal, but when i turn it to crank....nothing, nothing at all, not even a click, just silent and the lights dim a little. idk if it's a wire i'm not seeing is broke or something or if this is a common toyota problem, or if anyone else ever had this problem. please give me your input as soon as you can. thanks
Remove the starter, and take it apart at the back of it. Inside there will be a brass plunger and 2 cooper contacts. Replace the contacts and smooth out the plunger. Reassemble and start it. Should take care of it. Pretty common with Toyota's.
done, all new, still dont work, checked all fuses abd relays, still nothing.
ZONAYODA
07-13-2015 07:17 PM
