Sponsored by: CARiD
starter problem, please help!
Old Apr 6, 2011 | 12:22 PM
kawasakilewis's Avatar
Angry starter problem, please help!
i have a 91 toyota pick up 2wd automatic with the 22re motor, it would always fire right up but now it just quit, i have a brand new battery that was tried on other vehicles so i don't need it load tested, and i just got the starter checked and got some things replaced in it and it was directly tested and it works good, when i turn the key on all lights light up and everything is normal, but when i turn it to crank....nothing, nothing at all, not even a click, just silent and the lights dim a little. idk if it's a wire i'm not seeing is broke or something or if this is a common toyota problem, or if anyone else ever had this problem. please give me your input as soon as you can. thanks
Old Apr 6, 2011 | 12:38 PM
Junkers88's Avatar
If you don't hear a *click* then it is probably the starter relay. I believe it's on the passenger side fender well. Yes this is a common problem.
Old Apr 6, 2011 | 12:46 PM
waskillywabbit's Avatar
Hit the starter with a hammer then try it again.
:wabbit2:
Old Apr 6, 2011 | 12:48 PM
peckinpah's Avatar
And keep in mind that the starter relay is bolted in, so you have to take out the entire fuse box to remove it. If you try to pull it straight out, it will break and not come out.
Old Apr 6, 2011 | 12:49 PM
James Woods's Avatar
I had this problem in my wifes 4runner and it ended up that the negative terminal on the battery was cracked on the underside so I couldn't see it without removing it and inspecting it.
Old Apr 6, 2011 | 12:59 PM
Junkers88's Avatar
:wabbit2:
*laugh* Which is why I keep a hammer under the front seat.
Old Apr 6, 2011 | 03:56 PM
Zim's Avatar
Zim
Remove the starter, and take it apart at the back of it. Inside there will be a brass plunger and 2 cooper contacts. Replace the contacts and smooth out the plunger. Reassemble and start it. Should take care of it. Pretty common with Toyota's.
Old Apr 6, 2011 | 05:10 PM
wolfman81yota's Avatar
check all of the contacts. sometimes it's a bad hot lead to the starter. i know you said you just had it fixed, but just double check it.
Old Apr 6, 2011 | 06:05 PM
done, all new, still dont work, checked all fuses abd relays, still nothing.
Old Apr 6, 2011 | 06:42 PM
95blackToy's Avatar
Check the ignition switch. that could be it.
Old Apr 9, 2011 | 01:48 AM
wyoming9's Avatar
Red face
This is a automatic have you checked the neutral safety switch to be sure it is not stuck in the open position ??
These vehicles are known for poor ground cables from new . For peace of mind I always upgrade them when ever I get a new Toyota through my shop.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
clok
Aug 1, 2015 09:42 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
ZONAYODA
Jul 13, 2015 07:17 PM
colinmil
Jul 6, 2015 04:03 PM
