Rear turn signal not working.
So my left turn signal is blinking twice as fast as my right one and so i checked both the front and back on the left side and the rear one is out. I opened it up and both bulbs don't look burned out. The fuse under the driver kick panel for turn signal is fine also. Should i check the front left turn signal even though it appears to be working or change the rear turn signal bulb even though it looks fine? Any other suggestions?
instead of buying a bulb first try putting the bulb in question into the other side and see if that side starts blinking faster. If it does then buy a bulb. if not then you got another issue.
The right bulb worked when i switched them. Good call. Just bought a new bulb at napa and everything's good to go. Brain is functioning a little slow this morning. Thanks guys.
06-01-2021 01:51 PM
88yodabasket
07-13-2015 01:32 PM
